Author Topic: Engine not starting!  (Read 11582 times)
Offline topher
  • Administrator
  • fully functioning
Re: Engine not starting!
« Reply #10 on: 30 April 2014, 20:27 »
oo its a cobra, i thought you had the factory immo. in that case you could try bridging the fuel pump relay if you cant find the fob to reset it
Offline mr.wrightside
« Reply #11 on: 01 May 2014, 11:02 »
I drove my car like usual, got home, parked it, went to it the next day and it just wouldn't start and had no spark and fuel injector wasn't activating when I turned the ignition. So ignition coil isn't cracked or anything? A few people were having similar symptoms with that issue.  And the E30 relay was $40 from my VW dealer, was going to buy used but thought I better not with the relay haha. Worth replacing since it's a pretty cheap option.
Offline Len
« Reply #12 on: 01 May 2014, 11:56 »
Sure I have the fob with the spare set of key/alarm fob.
Just a matter of finding those!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #13 on: 06 May 2014, 09:04 »
Found fob easily, but still no go!
Need a good auto-electrician me thinks! Will see what vag-com throws up!
A mate has a proper one so see when he can come look.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #14 on: 10 May 2014, 18:04 »
Codes tested, only one fault!  Crank sensor  :angry:
Wish I hadnt wasted time on the alarm/immobiliser now!
www.sas.org.uk
www.the-ace.org.uk
Offline topher
  • Administrator
  • fully functioning
« Reply #15 on: 10 May 2014, 19:45 »
didn't you say you had a brand new crank sensor? mk3's will report a crank sensor fault if the engine isn't running when you scan them.. could be a red herring.
Offline Jasikasisback
« Reply #16 on: 10 May 2014, 22:16 »
check the timing and dizzy position....
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 10 May 2014, 23:57 »
I thought it was the hall sensor that came up when the engine isn't running .
Offline topher
  • Administrator
  • fully functioning
« Reply #18 on: 11 May 2014, 00:48 »
yeah you're right.. i don't have to work on many mk3s anymore, thankfully :grin:
if the crank sensor was a genuine item it could be wiring. cheap sensors on the other hand can be faulty right out of the box.
« Last Edit: 11 May 2014, 00:51 by topher »
Offline Len
« Reply #19 on: 11 May 2014, 16:41 »
Crank sensor was the only code that showed up.
Was cleared then engine start attempted and fault re-appeared straight away.
Yes it was a new crank sensor, a Febi part.
www.sas.org.uk
www.the-ace.org.uk
