Author Topic: 1986 MK2 ABF help needed plz  (Read 6637 times)
Offline Screech16v
  • MK3 20vt AGU
Re: 1986 MK2 ABF help needed plz
« Reply #10 on: 28 April 2014, 18:57 »
They don't have a maf lol
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 28 April 2014, 19:05 »
My abf was mega reliable,i did have a ,misfire issue once though but sorted it straight away by replacing the ecu relay 30,symptoms were rough idle and bad misfire low down and mid range.
Offline bamfish89
« Reply #12 on: 03 May 2014, 13:11 »
what do u mean the dont have a maf? whats the thing plugged in just after my air box?
i thort they did lol well ill give that a go i think i have another relay 30 but i dunno if mines gonna be different as its a different fusebox?
cheers mr mark!
oh are you playng cars this weekend at all?
Offline weazgti
« Reply #13 on: 03 May 2014, 14:02 »
As above relay 30 and disconnect lambda sensor plug.
Think a pic of what you think is a maf is needed because it's just inlet boot straight to throttle body
Offline Screech16v
  • MK3 20vt AGU
« Reply #14 on: 03 May 2014, 18:18 »
cheers mr mark!
No mate they don't have a maf,that sensor is intake temp,you will have relay 30,im in on Monday ,goin to chuck that turbo on,you can try my relay 30 aswell just incase you have a couple of dead ones if your about
Offline bamfish89
« Reply #15 on: 04 May 2014, 15:54 »
Ooo rite i fort that was a maf lol so it wudeny be that then? And yes ill be there tomorrow so ill give the relay a go. Oooo bigger turbo time. Finally carnt wait to c the difference. What time u going in for?
Offline Diamond Hell
  • Opinions я Us
« Reply #16 on: 06 May 2014, 16:47 »
Get the fault codes read rather than trying to guess what the problem is!  :grin:
Offline ToddyGTi
  • I Love GTi's
« Reply #17 on: 16 May 2014, 13:59 »
The misfire could be anything from coilpack issues (common) to deteriorated HT leads.
Also, are you running the Lambda? Mine backfired and missed loads without it.
Part of the Booty Club
