Author Topic: Staggered set of wheels?  (Read 3959 times)
Offline Clifford125
Re: Staggered set of wheels?
« Reply #10 on: 22 April 2014, 15:45 »
I'm running 8.5j up front and 9.5j at the rear and needed 15mm spacers for the front.
Ehhh why did u need spacers I'm running the same as you without spacers??
Are you on coil overs?
I phoned up 3sdm and they said that the 0.01 wheels would fit with no spacers but some people say I need them.
Online Nino
« Reply #11 on: 23 April 2014, 06:45 »
If i didnt use spacers they would of hit my jom coilovers.
« Last Edit: 23 April 2014, 19:15 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline dom
  • Back in a Mk4
« Reply #12 on: 23 April 2014, 08:50 »
coilovers
What size tyres?
Offline Carl!
« Reply #13 on: 23 April 2014, 19:07 »
coilovers
What size tyres?
300/35/18  :wink:
Online Nino
« Reply #14 on: 23 April 2014, 19:16 »
coilovers
What size tyres?
I only required spacers on the front which are running 215/40/R18 rememeber my front are 8.5j not 8j.
Offline dom
  • Back in a Mk4
« Reply #15 on: 23 April 2014, 20:18 »
I'm also running 215/40/18 on 8.5J. I'm just surprised that you needed a 15mm spacer, 99% of the time a 5mm would do.
Offline Clifford125
« Reply #16 on: 23 April 2014, 20:55 »
If I have 225/40/18 do you think I might need more than a 5mm spacer?
also could I use the same wheel bolts on a 5mm spacer?
Offline dom
  • Back in a Mk4
« Reply #17 on: 23 April 2014, 23:35 »
Yes and yes :afro:
