Author Topic: I just for the life of me get my head round the catch can  (Read 6345 times)
Online Nino
Re: I just for the life of me get my head round the catch can
« Reply #10 on: 21 April 2014, 09:52 »
I need to get this nailed and rio, ive seen what rocker has hopefully he will reply soon
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline rockmonkey69
« Reply #11 on: 21 April 2014, 14:22 »
No, the T pieces goes between the rocker cover and top inlet of the catch can and goes down to the block opposed to the hockey puck.
The lower catch can inlet goes directly to the hockey puck.
Excuse the poor edit of your pic, but you'll get the idea:
As above, that is indeed the correct route.
The elbow for the crankcase breather from the block can be replaced with a billet adapter, a few companies sell these now, I purchased mine from integrated engineering
http://www.performancebyie.com/integrated-engineering-billet-block-breather-adapter-for-1-8t-mk4-2-0l
And of course I just used my valve cover as a t-piece
« Last Edit: 21 April 2014, 14:24 by rockmonkey69 »
Online Nino
« Reply #12 on: 21 April 2014, 18:12 »
Very interesting, your link only shows the red part?
« Reply #13 on: 21 April 2014, 18:30 »
All the other hoses, fittings and adapters were purchased separately from other vendors. Depending what route you plan to plumb the crankcase breather you will need different angle fittings. They are easy to source, it is only the block crankcase breather adapter (red part) that is unique to a few vendors that's why I thought to include the link for that.
Online Nino
« Reply #14 on: 21 April 2014, 21:11 »
Arhh okie dokie cheers for that :)
Offline Dalo Harkin
« Reply #15 on: 22 April 2014, 08:31 »
forgive me jumping in, but what difference does it make what goes where in the catch can, don't all the gases end up in the catch can anyway  :undecided:
« Reply #16 on: 22 April 2014, 08:45 »
A well routed system will better evacuate crankcase gasses and prevent an excessive build up which normally leads to the oil dipstick popping up and oil forcing it's way through the oil filler cap. So it should be fine as long as this doesn't happen.
While moving the t-piece on a system ventilated to atmosphere is fine, doing so on the above with a catch tank fitted will effectively mean gasses from the rocker cover breather will bypass the catch tank.
« Last Edit: 22 April 2014, 09:00 by rockmonkey69 »
Offline Dalo Harkin
« Reply #17 on: 22 April 2014, 12:29 »
so am I right in thinking it doesn't matter which line the T piece is in, was what I was getting at.. I don't want to chop all mine up again to route a different way unless its essential.
I don't have the hockey puck in mine as it was broke so its just a 90 degree piece of plastic now into the TIP, that routes to the T piece where one side goes to the catch can and the other to the oil breather part and then I just have the crankcase directly to the other catch can inlet
Offline rio_gti
« Reply #18 on: 22 April 2014, 13:15 »
both the breathers need to enter the can first... or there would be no point in having the can there  :wink:
Offline dom
  • Back in a Mk4
« Reply #19 on: 22 April 2014, 13:23 »
As Rio says, you need a single line going from the catch can to the TIP.
The whole idea is that the breathers both filter through the catch can to catch all of the 'gunk' to prevent it from entering the TIP.
