Author Topic: Anyone running a RAMAIR induction kit?  (Read 7663 times)
Offline viperjsy
Re: Anyone running a RAMAIR induction kit?
« Reply #10 on: 18 April 2014, 23:10 »
hi what size neck is the Ramair please
« Last Edit: 18 April 2014, 23:12 by viperjsy »
Offline Nino
« Reply #11 on: 19 April 2014, 06:55 »
80mm if i remember correctly
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline viperjsy
« Reply #12 on: 19 April 2014, 15:37 »
thank you Nino
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
« Reply #13 on: 19 April 2014, 16:09 »
If ur interested dom - black and red s2000 filters on ebay if you search for 'blueprint s2000 filter',  since Ramair is on topic u can also buy 70mm & 80mm direct fit Ramair cones
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #14 on: 19 April 2014, 17:30 »
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline viperjsy
Offline Dalo Harkin
« Reply #16 on: 29 April 2014, 19:31 »
would be good to see how these compare to the S200o filter in terms of flow
« Reply #17 on: 29 April 2014, 21:21 »
hi just purchest this http://www.ebay.co.uk/itm/390487325223?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Get the 80mm cold air feed pipe off them too. I just got some off them for mine the other day. R-Tech recommended me to use the cold air feed to the filter
Offline viperjsy
« Reply #18 on: 30 April 2014, 01:01 »
going to see if I can still use the standard air feed if I cant I will get one when I can afford one
« Last Edit: 30 April 2014, 01:11 by viperjsy »
Offline MarcIV
  • Mk4 GTI
« Reply #19 on: 30 April 2014, 01:13 »
Mine is massive, I personally rang Ramair and spoke to Ryan, he was extremely helpful and all in all it cost me £60 delivered with the reducer, it sounds great and I was told it will hold up to 310bhp and i can have any color been in my car for about a year and a half I defo felt a throttle response after fitting this.
I want one!
Flash Red Mk4 golf 1.8t GTI :)
