Author Topic: How much boost....  (Read 2825 times)
Offline Dalo Harkin
Re: How much boost....
« Reply #10 on: 28 April 2014, 12:45 »
Just an update, was out on Saturday and the boost blew one of the front boost pipes off the FMIC  :shocked:
So got home and refitted it all again (bumper off job) in all fairness the jubilee was slightly twisted, so replaced and all seems well again....
I just want to double check the boost is ok, so is there anything I can do to see if its over boosting?
1.7 Bar just seems ridiculous and I don't want the turbo or something else going bang after spending time and money sorting it
Offline Scott D
« Reply #11 on: 28 April 2014, 13:44 »
1.7bar seems a lot
VCDS logging specified vs actual boost would probably show a clearer picture. Is it spiking to 1.7bar or holding?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Rhyso
« Reply #12 on: 28 April 2014, 14:39 »
Have you spoken to Nick @ Carbon??  He will be able to give you the answer as to what its requesting  :smiley:
If its a new turbo if may have a couple of turns too many on the actuator  :undecided:
Offline Dalo Harkin
« Reply #13 on: 28 April 2014, 17:37 »
Its spiking to 1.7 and then tailing off
Offline Dalo Harkin
« Reply #14 on: 28 April 2014, 17:38 »
That was my next point of call
