Author Topic: Front Brake caliper  (Read 5140 times)
Offline Stevie35
Re: Front Brake caliper
« Reply #10 on: 11 April 2014, 12:19 »
So how do you get your front pistin back in andy? G-clamp? Use the wind back tool with a double depth in they are torx screws not phillps head
You just squeeze the piston on front calipers. If I'm changing discs and pads just use a flat head screwdriver, once the brake fluid cap is off just use the old pads against the old disc to squeeze the piston all the way back before dis-assembling the calipers.
Edition 35 3dr, Steel Grey, Manual, Sat Nav
Offline Mattyj
« Reply #11 on: 11 April 2014, 15:01 »
Pffft just as as easy to do it my way
Offline Olifran
« Reply #12 on: 11 April 2014, 15:05 »
Don't forget to remove some fluid (if it's been topped up over time). You should be ok if the level of the fluid has gone down with the pads wearing. I was ok when I did mine.
Now - MK7.5 R in Pure White with DCC.
Gone - 2014 Mk7 GTI DSG Pure White - Discover Nav - Park Assist - Winter Pack.
Offline Mattyj
« Reply #13 on: 11 April 2014, 18:05 »
Genuinely never had this issue neither have i had to remove reserviour cap if i'm doing it wrong then stupid me but i understand the theory
Offline Stevie35
« Reply #14 on: 12 April 2014, 07:38 »
If you don't remove the reservoir cap you can build pressure in the system which could result in popping a few seals in the calipers it's a closed system and your trying to compress it that's why you take of the cap to help relieve the pressure.
Also some garages where mechanics have become zombie technicians no longer have the brain cells to check weather low brake fluid means a pad change so when they see the fluid low they just top it up then when u go to change the pads u have excess fluid in the system which if not removed will just spill out.
Offline Jimmgc51
« Reply #15 on: 12 April 2014, 09:34 »
Hmmm can't say ever removed the cap either. I thought the pressure would find it's way back to the reservoir tank in the engine rising the level?
You say pop a seal how would you know?
Golf GTI 09, CW, Bi-Xenon, DCC, 18" Monza's, Jakarta, RNS510, Dynaudio, F&R parking sensors, Winter pack...
Ibiza Deep House mix for DL - https://soundcloud.com/jimmgc51/getting-deep-with-house
Offline Mattyj
« Reply #16 on: 12 April 2014, 15:02 »
My arguement to that is your letting air into a sesled system by your reackoning
Offline Stevie35
« Reply #17 on: 13 April 2014, 08:51 »
Well if you pop a seal on you caliper you brakes won't work and you will have brake fluid coming out the dust cover
Also as for letting air into the system your not letting any air in your just allowing a non pressurised path for the fluid to return back to the reservoir.
Everyone may not do it like this but that's how I was shown to do it properly, by a mechanic
Offline Stevie35
« Reply #18 on: 13 April 2014, 09:17 »
Here is a guide from another forum saying to open reservoir cap before pushing front or rear calipers back.
http://www.r32oc.com/topic/35696-fitting-brake-discs-and-pads/
Offline Mattyj
« Reply #19 on: 13 April 2014, 10:38 »
This doesn't prove your point its just someone else who agrees with yo
