Author Topic: Oil light keeps coming on  (Read 2447 times)
Offline sammy90
« on: 06 March 2014, 02:01 »
I've had the car 2 days it's a mk4 gti turbo I checked the oil and it was just under minimum so I topped it up until it reached the maximum line everything was fine and now it keeps beeping then the oil light comes on and it says STOP CHECK OIL so I let the car cool down over night checked it in the morning and it was still on max and it happens again today would this be a dodgy sensor ?
Offline dom
  • Back in a Mk4
Re: Oil light keeps coming on
« Reply #1 on: 06 March 2014, 10:21 »
More likely to be a blocked oil pickup pipe, I wouldn't drive it until it's checked out
Offline sammy90
« Reply #2 on: 06 March 2014, 11:28 »
Where are they located and are they easy to unblock?
« Reply #3 on: 06 March 2014, 12:31 »
You will need to drop the sump, better to replace than trying to clean it out tbh.
Offline sammy90
« Reply #4 on: 06 March 2014, 12:40 »
Ok some one told me it might be the oil pump the car has done 160k hope it ain't the pimp means a engine rebuild :(
