Author Topic: HELP identifying some weird wire !  (Read 3328 times)
Offline naut2k5
Re: HELP identifying some weird wire !
« Reply #10 on: 31 August 2005, 13:01 »
Not sure mate, it disappears out of site !
Anyone know where it goes? If i had the time and the space I would take this whole car apart !  :rolleyes:
« Reply #11 on: 31 August 2005, 14:53 »
That wire should go from one of the bolts on the coil bracket to that bolt on the rocker cover, you can see on your pic that it has snapped and is now hanging loose!  You'll need to replace it, get down your local scrappy pretty much all VWs should have an earth lead similar to that :)
Edit: Those other 2 wires you show are actually in the correct place on your engine, the 2 blue connectors bolted to the rocker cover shown in the other picture are in the wrong place :grin:
Not that it matters as long as they get a decent contact to the block or the chassis it doesn't matter where they go :)
« Last Edit: 31 August 2005, 14:57 by rubjonny »
Offline Mr Blue
« Reply #12 on: 31 August 2005, 14:57 »
Eh? Another one!  :lipsrsealed:
I thought these two are earth straps - you'll notice in the pics they are in the wrong spot though!
So, now im more confused, unless the wire (from my first pic) that came off is incorrectly placed too  :undecided:
ive helped wire a few of my mates mk2's and them two wires should be fine. just clean them up. Normaly if one of those are disconnected. the engine wont start or the wipers wont work. in my experience :rolleyes:
Offline naut2k5
« Reply #13 on: 31 August 2005, 15:07 »
Will have a go tonight and let you know !
I'm hoping the same thing doesn't happen again and I blow this ecu...
Or there are more probs!  :shocked:
Offline naut2k5
« Reply #14 on: 31 August 2005, 18:33 »
Ok guys .. so i cleaned the earth straps.....put the new ecu in and the charged battery ....
When i just turn the key once ... i hear a strange buzz...its not there when the ecu is out ..... dodgy ecu ... what u guys reckon .... think I might just give it a go and see if it works..
 :undecided:  :undecided:  :undecided:  :undecided:  :undecided:
« Reply #15 on: 01 September 2005, 10:40 »
That'll be the fuel pump priming, it means your ECU is working :)
Check the buzz actually comes from the pump though and not from an electrical fire somewhere! :grin:
The pump is mounted under the car just in front of the driver side rear wheel, and should always prime for a second or so when u turn the key.
Offline Rain
  • forum irregular
« Reply #16 on: 01 September 2005, 22:37 »
buzzing comes from the isv not the fuel pump that only primes and stops the continous buzz is the metal thing on the manifold with rubber tubes coming from each side is the isv. that strap in the picture jim is a black thin strip and its the strap from the coil to the block goes in the same place as the earths. and problems give me a bell and ill pop over the weekend and sort it out for ya
