Author Topic: Is the handling genuinely this sh!t?  (Read 4069 times)
Offline navmk4gti
Re: Is the handling genuinely this sh!t?
« Reply #10 on: 26 February 2014, 09:18 »
A stock fwd..handles sh1t yes..not all mk4s...dont see a lowered one with all the arbs etc being any good as a fwd with lsd or a 4wd tho. They should have made them all with the haldex system  :evil:
Offline GTi_James
« Reply #11 on: 26 February 2014, 12:24 »
i murk soopa cars man dem ent got nuttin on me on b roads trus had a gtr otha nite
Edit - you've got until midday today to translate this into English otherwise it will be deleted.
BAHHAHAHAHAHAHAHA! :laugh:
Offline mcgee9t2
« Reply #12 on: 26 February 2014, 12:48 »
anyone else shocked by the fact that is wheel spins in 3rd and 4th. id say you have sh!te tyres on...
Offline daz veedub
  • Operation 1.8t bolf
« Reply #13 on: 26 February 2014, 13:42 »
Deck it
Offline Organisys
  • Old and Slow...
« Reply #14 on: 26 February 2014, 14:06 »
I'm not trying to be an arse here, but if I owned a Mk4 and I wanted my car to handle, instead of squanderign money on bushes, ARBs, shocks, springs, Coilovers, whatever.. I'd just save up my money and buy a Mk5. The difference in handling is frankly astonishing.
 :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #15 on: 26 February 2014, 14:46 »
Second Edit - Too late - sorry!
Blud dis evn funier!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline GTi_James
« Reply #16 on: 26 February 2014, 15:46 »
i fear for the future generations  :lipsrsealed: :laugh:
Offline Bellend
« Reply #17 on: 26 February 2014, 17:51 »
Michelin's but it's only over bumpy roads.
Definitely needs a stiffer rear. I think some sort of 30mm shock and springs set will do with some bigger brakes and ARBs.
Where all my moneys went.
Offline D1andonlyantman
« Reply #18 on: 26 February 2014, 18:40 »
 :smiley:
I haven't come here to slag off mk4's because i did love mine and had plans for it, but it was only after I got the LCR I realised how badly the golf handled. I had it through the winter so conditions weren't ideal a lot of the time but the understeer was insane. It probably wasn't on the best rubber from the PO either but the money you're going to spend sorting out the handling on the mk4 could be put towards a car that has half decent handling from the start. If it's a labour of love then none of that matters, obviously :)
MKIV AUQ - RamAir Induction Kit, Forge007p, (Custom Exhaust, Decent TIP, N249 Bypass and remap coming soon)
TRASHED BY SOME BELLEND WHO CANT DRIVE
Replaced with Leon Cupra 225, RamAir CAI, Forge 007p, Badger5 TIP, N249 bypass, Scorpion Decat and Catback, R-tech remap pushing approx 275bhp :-)
Offline Scott D
« Reply #19 on: 26 February 2014, 18:54 »
I found fitting purely an anti rear roll bar made a massive difference then combined with rear axle bushes, 40mm suspension kit and good summer tyres handling massively improved.
Changing dogbone mount and stiffer engine mounts helps with wheel hop and I rarely have issues putting power down in corners by partly down to linear throttle mapping and not mashing the foot down.
MK4s's as standard aren't great handling cars but do respond well to basic handling upgrades
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
