Author Topic: Ending a phone call  (Read 6406 times)
Offline dippy_x
Re: Ending a phone call
« Reply #10 on: 27 February 2014, 20:17 »
So today I noticed - when you get an incoming call - the MFD and the CMS both display the incoming call detail.  If you answer on the CMS the MFD goes back to driving data and the only way to end the call is to end call on the CMS which may no longer be there if you have sat nav.  You can press phone at the side of the CMS or cycle the MFD to the call display and end using the button on the steering wheel.  If you answer the call using the steering wheel/MFD then your CMS stays as is and you can end the call using the steering wheel.  This seems to be the best way.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline KyleB
« Reply #11 on: 28 February 2014, 17:12 »
No matter how I answer a call, pressing the phone on the steering wheel takes me immediately to the phone menu in the MFD, from there I can end the call by pressing the phone button again or the ok button. Easy enough for me, in fact I think that's easier than pressing a touch screen icon
Offline davyk31
« Reply #12 on: 28 February 2014, 20:06 »
I would have expected pressing the phone button would or should have ended the call. So is that buttons function only to answer a call?
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline KyleB
« Reply #13 on: 28 February 2014, 20:14 »
I think it takes you to the call menu so you can mute or hold the call if you want without needing to take your hands off the wheel.
Offline itavaltalainen
« Reply #14 on: 28 February 2014, 20:38 »
that is exactly how it works...
quite good it doesn't hang up on the phone button on the steering wheel. you have more options from mfd - nice to mute on a conference call while you're eating your breakfast  :whistle:
Offline stuart.cameron
« Reply #15 on: 12 March 2014, 15:19 »
Press the phone button the steering wheel twice hangs up.
Once to get it to the correct menu and once to hang up.
Current // Golf GTD 3dr DSG - Carbon Grey | Discovery Nav Pro, Keyless Entry, Park Assist, Reverse Camera, Winter Pack
Previous // Polo GTI 6r - Black | Xenons, MFSW, Winter Pack, Sensor Pack, Convenience Pack, Climate Control, RNS 510 w/Bluetooth
