Author Topic: Oil leak!??  (Read 3088 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Oil leak!??
« on: 24 February 2014, 21:38 »
I have an oil leak that seems to be coming from the top bit of the back of the block where the top arrow points. It has spilled down onto the turbo pipe which the bottom arrow shows in the picture. Any ideas what could be causing this. Is it the head gasket? or some type of seal   :undecided:
This picture is from above and shows the leak a bit better on the right side of the picture. You can see the actuator and downpipe below.
« Last Edit: 24 February 2014, 21:41 by oceanic-green »
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline sharki786
  • GOT BOOST??
Re: Oil leak!??
« Reply #1 on: 25 February 2014, 08:28 »
Rocker cover gasket?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
Re: Oil leak!??
« Reply #2 on: 25 February 2014, 09:34 »
That would be my guess.
Re: Oil leak!??
« Reply #3 on: 25 February 2014, 19:10 »
Thanks guys!  :smiley: Would this leak effect performance at all?
Offline northeast_gti-t
  • "1.8T AGU"
Re: Oil leak!??
« Reply #4 on: 25 February 2014, 19:21 »
+1 on this looks from your pic like the area of oil is from your cam cover,it shouldn't as a rule affect performance tho
2000 Mkiv GTi 1.8T AGU
Re: Oil leak!??
« Reply #5 on: 25 February 2014, 19:25 »
Cool. I am getting a new turbo, ported manifold and supersize tip fitted on Monday, so I will ask my mechanic to sort the gasket out as well.
  • "1.8T AGU"
Re: Oil leak!??
« Reply #6 on: 25 February 2014, 20:40 »
:afro: expect some pics then should be good,gaskets easy enough to replace also fit a new spark plug cover gasket to as they usually come as a pair  :wink:
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: Oil leak!??
« Reply #7 on: 25 February 2014, 21:00 »
Yeah same as mine, (failed twice). The gasket kit comes with spark plug seals too. Do you smell burning oil when stationary?
I thought Volkswagens were supposed to be reliable?
Re: Oil leak!??
« Reply #8 on: 25 February 2014, 21:02 »
Cheers, will get that done as well then!  :smiley:
Offline sharki786
  • GOT BOOST??
Re: Oil leak!??
« Reply #9 on: 25 February 2014, 21:31 »
Make sure you ask if it comes with the spark plug gasket as i had to buy them seperatly from tps.
*****MK4 GTI T*****
