Author Topic: Running issues mk3 gti 8v  (Read 2372 times)
Offline wayedy
  • GTI FOR LIFE
« on: 23 February 2014, 20:45 »
hi, iv a mk3 gti 8v, done around 156k, just bought 4 days ago, it first started  to cut out when i drive it down the road in cold weather just when im dipping the clutch when coming to stop at lights or junction, or even turn into a road, the revs drop and oil light and battery light come on and engine cuts off,
very very slight misfire time to time, sometimes keeping the revs abit high helps, its starting to get annoying,
i know the guy sold it to me knows something but didnt tell, can anyone help me or have i just bought a messed up engine car, plz help im worried.
[/URL]
Offline itavaltalainen
Re: Running issues mk3 gti 8v
« Reply #1 on: 23 February 2014, 20:54 »
what's the engine code mate?
on 2E it'd have a look at idle valve (aka cigar) + ignition coil...
on ADY, AGG ignition coil and maybe throttle dirty....
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 23 February 2014, 21:01 »
Would defo clean the throttle body first .
Offline wayedy
  • GTI FOR LIFE
« Reply #3 on: 23 February 2014, 22:44 »
OKAY thanks guys, will give an update tomorrow. :evil:
[/URL]
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 24 February 2014, 07:31 »
Id also be checking the cable on the crankshaft sensor (it loops round the back of the oil filter and often perishes due to heat)
« Reply #5 on: 24 February 2014, 09:01 »
If it has a crank sender (2E doesn't)
Offline Callum_K
« Reply #6 on: 24 February 2014, 09:37 »
If it's just when dipping the clutch and coming to a stop etc, it will be the throttle body. Clean and realign, should sort it. Crank sensor issues would cause it to cut out out completely at random, not just when dipping the clutch, and would fail to restart immediately
