Author Topic: Vagcom Errors - In need of a little advice...  (Read 10337 times)
Offline jonnyb
« on: 21 February 2014, 19:20 »
Hey folks, did a scan on my Mk5 gti tonight, as i just got my VCDS cable :D
It's spat out a few code errors, which i'd like to clear up.  Firstly, none of these errors are affecting the working of the car (not that i know of), but i'd still like to remove them.
It's also worth noting that there are a few relating to lights, this may be due to some aftermarket DLR's that were installed by the previous owner.  If i could fix that, it would be good, as i do get intermittent light error light on my dash.
Cheers in advance,
Code: [Select]
[i]Friday,21,February,2014,18:28:06:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H15---    Serial number: VWZ7Z0E2362279
   Coding: 0403000318070160
   Shop #: WSC 00674 210 92229
   VCID: E3C5C90722A0E306691-80B6
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 408FA68B1376181ED43-8015
Address 08: Auto HVAC        Labels: None
   VCID: 55A167DFBCF48DB6975-8000
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001960042
   Coding: E78F8F2700041800001400001400000000087F075C
   VCID: 2B55E1278AF0EB46111-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
1 Fault Found:
02395 - Parking Light Front Right (M3)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 178
                    Mileage: 146750 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 11.95 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0GW0XX
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 377DCD5746B85FA6659-8062
   Subsystem 1 - Serial number: 6332MSME0A7B256BN
   Subsystem 2 - Serial number: 6342MSME0B4E0326C
   Subsystem 3 - Serial number: 6351HSME076D4E35J
   Subsystem 4 - Serial number: 6361HSME075B07334
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenks‰ulenmodul 634 0070
   Coding: 0000042
   VCID: 76E300530132E6AEBEF-8023
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972
   Component: KOMBIINSTRUMENT VDD 1112
   Coding: 0007403
   Shop #: WSC 00080 210 88524
   VCID: EFEDB537FE685766FD9-80BA
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056270600
   Coding: 7D0F0748070001
   VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 138
                    Mileage: 146748 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:58:44
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1112
   Shop #: WSC 01069 210 65116
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680
   Component: RNS-MID       H74 1300
   Revision: AB001001    Serial number: VWZ6Z7I1376111
   Coding: 020004000400002200
   Shop #: WSC 01324 785 00200
   VCID: 2E53E83379E29E6E36F-807B
3 Faults Found:
00857 - CD Changer Unit (R41)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 138
                    Mileage: 146744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:00:46
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 138
                    Mileage: 146744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:00:54
01299 - Diagnostic Interface for Data Bus (J533)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 146748 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:58:48
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2306
   Coding: 0000564
   VCID: 3663C05341B2A6AE7EF-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   Shop #: WSC 00000 000 00000
   VCID: 3365F94752C0B386591-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AQ    HW: 1K0 959 433 AQ
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 999002085103087F2D040C0DF0085AC690A440
   VCID: 7F0DE5772E08A7E6ED9-802A
   Subsystem 1 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4E7BA5B974E74BE00B-80A1
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 6
                    Reset counter: 138
                    Mileage: 146744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:00:46
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 4
                    Reset counter: 138
                    Mileage: 146744 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:00:54
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 138
                    Mileage: 146748 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:58:48
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D51EF3FB4E4E5760F5-8078
End   ---------------------------------------------------------------------
[/i]
Offline topher
  • Administrator
  • fully functioning
Re: Vagcom Errors - In need of a little advice...
« Reply #1 on: 23 March 2014, 14:14 »
when it comes to aftermarket drls be thankful that the issue is only intermittent. it could mean a bulb is slightly dodgy or some other form of resistance the ecu is picking up. the other faults just look like an aftermarket stereo has been fitted.. if thats the case you could tidy up the can gateway coding but its not essential.
Offline jonnyb
« Reply #2 on: 26 March 2014, 20:47 »
Hmm, wasnt aware the RNS 510 was fitted aftermarket, is there anyway to tell what it got out of the factory?
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 26 March 2014, 21:05 »
you can usually tell from the PR codes on the sticker in the boot if you enter them here http://igorweb.org/equidec/
if you go in to the can gateway installation list make sure navigation is ticked, but radio isn't. If it all looks fine then just clear the codes and check again in a few days.. the fault frequencies are pretty low so if the nav is all working as it should then don't fret.
Offline jonnyb
« Reply #4 on: 27 March 2014, 08:10 »
Cheers Topher!
Why is it you uncheck radio?
I've checked my backup images i took of the selections, and it does appear both radio and navigation boxes are ticked.
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 27 March 2014, 19:55 »
The can system gets confused and starts looking for both, which doesn't really do any harm tbh. I'm just a bit OCD when it comes to module coding :grin:
Offline jonnyb
« Reply #6 on: 28 March 2014, 09:26 »
haha, nothing wrong with a bit of OCD! I've only just got my hands on VCDS so still a little nervous about changing things 'willy-nilly' so ive taken the current selections as gospel.
I'll change the coding over the weekend, reset the errors, and see how i get on.
I can't thank this forum enough for the knowledgeable folk it has on these matters.
Cheers!
