Author Topic: who is running a toyo sport fmic?  (Read 4875 times)
Offline sharki786
  • GOT BOOST??
Re: who is running a toyo sport fmic?
« Reply #10 on: 25 February 2014, 12:12 »
I have the eurojet fmic at over 300 bhp, did require a lot of cutting but apart from that is a good kit.
That's not the 2" one by the way
Rock, what size is that one then?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline rockmonkey69
« Reply #11 on: 25 February 2014, 14:54 »
2.5" piping, 2.5" inlet and outlet with an even larger core
Offline sharki786
  • GOT BOOST??
« Reply #12 on: 25 February 2014, 15:22 »
so you say the eurojet is worth it?
you got any pics of what you cut mate?
*****MK4 GTI T*****
Offline rio_gti
« Reply #13 on: 26 February 2014, 21:37 »
I had  to get a r32 bumper I didn't fancy hacking the original that much
Offline brewey
« Reply #14 on: 26 February 2014, 22:04 »
Why don't you get a cheap bumper from a breaker and hack it so worst case you still have a backup?
Or failing that an r32 rep can be had for dirt cheap (I know some look naff, but there are some decent abs copies out there).
2000 1.8T ARZ - OEM+
« Reply #15 on: 27 February 2014, 08:59 »
It should fit fine behind a genuine r32 bumper but the replica bumper will need trimming
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 27 February 2014, 13:11 »
Fu*k me half of the bumper is missing there. See if i get a r32 front bumper i need the side skirts and rear bumper otherwise its going to look daft wont it?
*****MK4 GTI T*****
« Reply #17 on: 27 February 2014, 13:18 »
A large amount of the intercooler and crash bar are still covered by the bumper, but the portion I've cut was because the bumper isn't deep enough, r32 bumper will be fine though.
Think it would look a bit odd with just the front as r32
Offline sharki786
  • GOT BOOST??
« Reply #18 on: 27 February 2014, 14:28 »
Just the front r32 bumper is £300 odd forna genuine. I cant be arsed with a rep as i know it will never look right and that will bug my tits off.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #19 on: 27 February 2014, 21:37 »
I got a 600x300x75 with 63mm inlets, Toyosports, on eBay. £70 I think?
Dave, have you got the link for this? As i seen the size your on about but it states that the inlet and outlets are 3"
*****MK4 GTI T*****
