Author Topic: retrofitting rear view camera  (Read 21355 times)
Offline stephenwmc
Re: retrofitting rear view camera
« Reply #10 on: 03 May 2015, 15:49 »
My kit came with a guide. The loom just runs along the passenger side sill and plugs into the back of the navi unit in the glovebox. I couldn't get access to the back of the fuse box for the positive feed so I had to tap into the navi loom for that.
It did need VCDS coding. The kit referred to the official vw coding system so I found the VCDS coding info on the web. There are two entries that need changing if you have parking sensors.
2013 Golf Mk7 1.4TSI SE in Black
« Reply #11 on: 03 May 2015, 16:01 »
Thanks Stephen, that's handy info.  :cool:
Offline TheR
« Reply #12 on: 17 June 2015, 10:28 »
Hi!
I would like to let you know I have just retrofitted the OEM kit into my MK7 R.
Fitting took about 2-3 hours.
Start with removing top, left and bottom boot trims.
remove old unit
fit new unit
cut plug off old unit
solder those wires to the new loom
route cables along existing loom down the right side of the boot
at the grommet take the blue/black wire to the existing loom plugs
solder the blue/black to the blue/black of the existing loom
at the car side of the grommet remove the black trim on the roof
continue running the remaining loom to the front down through the side panel
beside the rear seat
under the side sill 5 dr
through the b pillar
under the front sill
up the side of the bonnet release trim
into the dash behind where the old fusebox in the mk5 was
along the side of the feet vent
I used a conduit to run from the drivers side to the passenger side under the carpet
remove the sd / dvd player
remove the glove box detailed below:
remove the panel on the side like the old fusebox cover but on passenger side
remove the T20
2 x T20 on the bottom of the glovebox
open the glovebox remove the 3 x T20 from the top
remove the T20 from behind the sd / dvd player
remove the trim lowest part of the center console
unplug the light and the open sensor from the glovebox
remove the rubber tube for glovebox cooling
unclip the fusebox from the holder via the 3 tabs
remove the top pink connector holder from the left of the fuseboard
place the white fuse connector from the new loom into F18
replace the locking clip
replace fuseboard
put in the 7.5 fuse into the new fuse placeholder
unclip the blue block on the back of the sd / dvd player
unclip the two sides of the locking tabs
push in your new video feed (the last two wires) black and white into the block (furthest right 2 pins top and bottom)
re clip the blue plug
re insert into the full block
put everything back
take to VW for coding £59 for 1/2 hour coding and software update for the cam on the nav
if you want / need the reverse cam lines to move with the wheels you need the calibration @ £85 for 3/4 hour
Notes:
VW added the retrofit/refit code and the system accepted it and downloaded the software, but they could not see the video feed or connect to the control module
they returned the car to the front for me, seems the turning the car off and on made the video feed work.
I hope this helps
« Last Edit: 17 June 2015, 11:35 by TheR »
Audi A3 - 1999
Audi S3 - 2000
VW Golf MK4 GTI - 1999
VW Golf MK5 GTI - 2005
VW Golf MK7 R DSG 4Motion (Current)
Offline mcmaddy
« Reply #13 on: 17 June 2015, 18:19 »
Vcds will allow the coding if someone knows where to look. Certainly won't cost what VW have charged you though.
Offline stephenwmc
« Reply #14 on: 18 June 2015, 08:52 »
I got the codes from here for my retrofit:
http://www.motor-talk.de/forum/rueckfahrkamera-nachruesten-t4634449.html?page=3
They are in the second post from the bottom. The page is in German but Chrome does a fair job of translating it.
Offline TheR
« Reply #15 on: 18 June 2015, 19:47 »
coding isnt the issue calibrating the system to function as normal is...
Audi A3 - 1999
Audi S3 - 2000
Offline Gnasher
  • Formerly GnasherVXR
« Reply #16 on: 19 June 2015, 07:22 »
Are the lines on the video feed meant to curve?
They don't on my factory fit camera but the parking sensor display does show the arc of the steering.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline mcmaddy
« Reply #17 on: 19 June 2015, 08:34 »
No, lines on video feed are fixed it's just the parking sensors that bend.
Offline Gnasher
« Reply #18 on: 19 June 2015, 15:38 »
Cool - from the description above I thought mine was knackered!
Offline whogives
« Reply #19 on: 08 October 2017, 17:56 »
Hi ............ I see this is an old post ..... Hope you don't mind me asking a question ........... I see you fitted your retro reverse camera on your mk7 ........ I'm just finishing mine ........ you mention about the white wire going into the fuse box the adding the 7.5 fuse ....... is this a permeant live ???? as I cant get to the back of the fuse box, so was going to connect elsewhere with a inline fuse.... what are your thoughts ?????
