Author Topic: 1991 Tornado Red Corrado G60 Daily / Project  (Read 63361 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: 1991 Corrado G60 (Update 26/3)
« Reply #10 on: 29 March 2014, 13:00 »
Yeah they seem to be the only distributor in the uk. Expensive for a length of braided hose but they are specic to the lubrication needs of the charger. Going to order one soon as wont be able to run it without it.
Offline matt@onlychargeddubs
« Reply #11 on: 29 March 2014, 19:33 »
Ouch! Just read through and a real shame it gave it on day 2! Those injector looms a serious issue though after 20 years!
Every car I get in is the same though if the engines never been out!
As for the feed line, you're right, they aren't cheap! It's due to the internal diameter VW used meaning the banjo ends are very odd and unusual to most hose specialists.
Hence me being the only Uk supplier of them as I've them made especially for me :)
Offline clipperjay
« Reply #12 on: 29 March 2014, 20:02 »
When first installing that stupid banjo check for oil leaks before you drive off trust me one washer missing, can give you a world of pain.
 I remember picking mine up it cost me about £40 odd quid when it was last in stock, stupid design to share oil path ways from main block to charger feed!!!!
I was tempted to fabricate complete separate feed, clean free of crap oil on tap from a mini pump & reservoir!
Offline Gti_Jamo
« Reply #13 on: 29 March 2014, 20:28 »
Yeah mate i'll be ordering one of those from you on monday when I get paid so you'll need to get that out to me sharpish lol. Need to see if there is anything else on the site I fancy.
Yeah don't worry it'll be checked meticulously before it goes anywhere mate. Least of my worries lol. Yeah it is a strange setup for the oil feed but probably the cost effective way of doing it.
How she sits this evening...
Offline clipperjay
« Reply #14 on: 30 March 2014, 10:06 »
Looking good mate do you own a workshop manual for the Corrado G60?
Offline Gti_Jamo
« Reply #15 on: 30 March 2014, 12:40 »
Cheers mate, no workshop manual unfortunately. You needing info on something particular?
Offline clipperjay
« Reply #16 on: 30 March 2014, 12:44 »
No I have the rare G60 Corrado Bentley manual some where so thought you might need it its PDF format and helped me out with the Rallye G60 no end!
Offline Gti_Jamo
« Reply #17 on: 30 March 2014, 12:54 »
I'm ok so far but cheers. Have autodata and a shelf full of old diagnostic books, many of which cover the G60. Served me well so far.
One think i'm not too clear on is the torque setting on the crank bolt. Obviously originally a stretch bolt but my new one isn't and quite rightly so.
Offline clipperjay
« Reply #18 on: 30 March 2014, 13:10 »
Non stretch crank bolt - N 040 106 4 DX bolt from memory! Use lock tight if its DX off a MK1
Torque values would be 59 lb/ft (80 Nm) for the non stretchy.
But if its a PG stretchy one then 200NM Quite a difference in Torque values
I would be tempted 100NM with lock tight
Offline Gti_Jamo
« Reply #19 on: 30 March 2014, 14:25 »
Well the original PG bolt has been revised but still carry original part number apparently. Don't do stretch bolts for them anymore so i've been told. Looks identical though.
