Author Topic: Resonator delete.  (Read 4295 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Resonator delete.
« Reply #10 on: 20 February 2014, 20:54 »
Can't beat a bit of weld porn
Offline barrym381
« Reply #11 on: 20 February 2014, 21:11 »
or a bit of polished bbs porn  :wink: was over seeing mike about some bits getting done
http://the-polisher.tripod.com/id20.html
Offline Prawny
  • R-tech power!!!
« Reply #12 on: 25 February 2014, 08:22 »
Hold on a minute there man!
You can't just post pics like that without some kind of explaination!  :cool:
What's the AN fitting let into the exhaust at an angle?
it looks almost as if it's plumbed into the breather system? some kind of gas evacuation setup?
More info required!
Offline rockmonkey69
« Reply #13 on: 25 February 2014, 08:58 »
Yes it's an exhaust evac for the Pcv system, it works fine and produces vacuum throughout most of the rev range but there is a point at the very top end of my rev when I produce quite a bit of back pressure in the exhaust making the check valve close and the dipstick pop out so I've disconnected it at the moment.
Offline Prawny
  • R-tech power!!!
« Reply #14 on: 25 February 2014, 09:43 »
Ah that's a shame, I quite like the idea, but mine lives at 5-7k so it'd probably not be too suitable.
Very cool idea though, where did you find a check valve capable of withstanding those sort of temepratures?
« Reply #15 on: 25 February 2014, 11:55 »
Yea, I might still use it only without the check valve, I just need to stick a gauge on it and make sure it produces vacuum and never any measurable pressure. The check vale is just a high flow billet check valve from torques.
Offline Prawny
  • R-tech power!!!
« Reply #16 on: 25 February 2014, 13:59 »
It's just dawned on me that it's your dyno plot I saw on b5 facebook. All makes sense now! nice result :)
« Reply #17 on: 25 February 2014, 14:52 »
Thanks buddy! it's so useable mapped as it is and I have to admit I am surprised the power held on so deep into the rev range. I am a difficult one to please but I am very content with the map.
Offline sharki786
  • GOT BOOST??
« Reply #18 on: 25 February 2014, 15:33 »
barry my man this guy is AWESOME!!! where is he based?
*****MK3 Anniversary*****
*****MK4 GTI T*****
