Author Topic: Help no reverse after gearbox change?  (Read 2597 times)
Offline maxey
Re: Help no reverse after gearbox change?
« Reply #10 on: 02 February 2014, 11:19 »
Ok thanks guys I will give this ago within the next hour il let u know my results :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 02 February 2014, 11:47 »
Ah another Isle of Wighter, howdy!
Offline maxey
« Reply #12 on: 02 February 2014, 12:22 »
Yes mate haha not good, I have a agu engine and there is not lock pin and my cables don't pull back they are different?
Offline maxey
« Reply #13 on: 02 February 2014, 12:39 »
Hole lots different in agu the shifter the cables and the gear stick has no locator pin?
Offline maxey
« Reply #14 on: 02 February 2014, 12:47 »
I have reverse only when putting it into reverse manually by hand moving the shifter, but moving the heartsick won't do it
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 02 February 2014, 13:24 »
You might have to change the whole lot Inc cables and Tower. My AGU has the later type shifter setup so I'm not clued up on the early design, I think it's similar to the mk3?
Offline maxey
« Reply #16 on: 02 February 2014, 13:49 »
Is there any mk3 guides?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline maxey
« Reply #18 on: 03 February 2014, 08:49 »
No luck :( not sure what to do now
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 03 February 2014, 21:12 »
Might be able to pop over to you Friday and have a play, will do it the old fashioned way
