Author Topic: What engine oil for GTD?  (Read 49303 times)
Offline itavaltalainen
Re: What engine oil for GTD?
« Reply #10 on: 01 February 2015, 15:00 »
Would there be an issue topping up the GTD with some Castrol Edge professional 0w30? The low oil light pinged and I've only got this stuff to hand.
This will not have 504/507 approval, which is the only oil allowed for diesels (DPF). If the 0w30 is ACEA C3 you're probably OK using it (unless it is old LL2 spec, i.e. VW 503.00 spec), though would check what manual says, think it says that you may use 0.5l other oil if LL3 oils are not available. Otherwise you'd theoretically void warranty (VW may check in case you have any engine trouble).
Offline KyleB
« Reply #11 on: 01 February 2015, 21:23 »
Yeah cheers, checked the dipstick and the oil level was in the middle between max and minimum. Went out in the car today and no error light came on, bit of a strange one.I'll pick up some correct oil just in case it does come back on.
Offline Mark V GTD
« Reply #12 on: 02 February 2015, 17:45 »
I got a litre of the correct Castrol stuff from an ebay seller - ten quid inc delivery....
Offline dippy_x
« Reply #13 on: 27 September 2016, 18:52 »
I had a low engine oil light today and popped into Shell.  None of their 5w30 oil has VW 507 listed on the back anymore.  It used to as that is what I bought previously.  Their 0w30 is rated for VW 507 now though.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
