Author Topic: Loud fan noise on cold start  (Read 5514 times)
Offline Mellls
« on: 23 January 2014, 13:42 »
Kicking myself for taking my Mk4 to an independent garage to have exhaust warning light problems dealt with...
Anyway, £300 down already, they've changed plugs and a coil it seemed ok when I collected it.  Today, when I started her up there was a really loud fan noise, I thought it was the climate control on full blast, turned it off and realised it was coming from the engine!!!  No warning lights, turned her off started up again and the fan noise was gone.  2 hours later, started her up, same thing.
The other thing I noticed was that she seems to be getting up to temperature a lot quicker than the usual 7-8 miles, was up to temperature after 2 miles.
I've searched through the boards guys, I can't find anything but I'm not sure what to put in the search... "fan noise" doesn't come up with anything.
Anybody got any idea, not sure if I want to take it back to the independent garage, especially after they said they didn't change my leads because they're hard to get too  :shocked: :shocked:
Offline mcgee9t2
Re: Loud fan noise on cold start
« Reply #1 on: 23 January 2014, 13:45 »
Fans usually kick in on start up for around 20 seconds.
Offline Mellls
« Reply #2 on: 23 January 2014, 13:50 »
Really?... I've had the car 6 months and it's never done it before  :huh:
Offline dom
  • Back in a Mk4
« Reply #3 on: 23 January 2014, 14:58 »
They charged you £300 to change the plugs and a coil?!! :shocked:
That's a 5 minute job and parts are less than £40...
Offline Mellls
« Reply #4 on: 23 January 2014, 15:05 »
Maybe they saw me coming!!!  He did say when I called that it was one of two coil things (I'm blonde), one was £30 the other was £160 and it was the £160 part that he fitted. Code reader charge of £30 and labour to walk round and round in circles I guess .... That's why I don't want to take it back over this new fan noise, which earlier post said was normal?
Offline dom
  • Back in a Mk4
« Reply #5 on: 23 January 2014, 15:17 »
I wouldn't be going back there in a hurry.
What year is your car? If it's a later one it might be the secondary air pump making the noise
Offline navmk4gti
« Reply #6 on: 23 January 2014, 15:19 »
Fook me they had you good. Mine also gets up temp within 2-3 miles. Start to worry if it goes over 90 temp.
When the fans kick in on start up does the car idle higher then normal too??
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #7 on: 23 January 2014, 17:46 »
I would agree with dom if yours has a secondary air pump it will be this you can hear its part of pre heating for the emissions and catalytic convertor etc
2000 Mkiv GTi 1.8T AGU
Offline Mellls
« Reply #8 on: 23 January 2014, 17:51 »
Yes, the car idles higher on start up, about x12 then it drops down to x8 where it usually idles when the fan goes off, is that normal then?
  • "1.8T AGU"
« Reply #9 on: 23 January 2014, 17:55 »
yes that's normal don't worry especially with the lower temps this time of year it is just an enriched fuel mixture for initial start up then as the engine warms the idle will drop back to where it should be
