Author Topic: DAMP ON THE LEFT SIDE OF MY BOOT FLOOR / CARPET !!!  (Read 1587 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Hi there lads, I've noticed over the last month or two that the carpet on the boot floor is getting, not wet but like very damp to touch, but its only on the left hand side ???  :undecided: the covering to the side of it / arch is perfectly dry !!! Its really bugging me cos the boot floor is constantly damp in that area, and its where I'm going to be fitting my watermeth tank and wana get it sorted
Anyone got any ideas ???  :smiley:
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: DAMP ON THE LEFT SIDE OF MY BOOT FLOOR / CARPET !!!
« Reply #1 on: 22 January 2014, 10:33 »
Damp can get through the vent behind the rear bumper if it's not sealed properly. It's worth taking it off and sealing round the vents with silicone
Offline dom
  • Back in a Mk4
« Reply #2 on: 22 January 2014, 12:46 »
I would have though it's more likely to be either the foam tail light seals leaking or a broken washer pipe.
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #3 on: 22 January 2014, 23:06 »
This happened to mine turned out to be the washer pipe had a split in it just replaced it and all good
« Reply #4 on: 26 January 2014, 02:10 »
Cheers lads ill check everything, and see how i go on, hopefully get it sorted  :smiley:
