Author Topic: VCDS Wiki - Help needed :) - Advice wanted!  (Read 21672 times)
Offline jivemonkey
Re: VCDS Wiki - Help needed :) - Advice wanted!
« Reply #40 on: 25 January 2014, 14:17 »
Just checked the site today and can't seem to find any entries?
Same here... :shocked:
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline noobmonkey
« Reply #41 on: 25 January 2014, 15:10 »
umm i kinda ruined it, have reset the filters... and well the entries are all back now :)
Sorry, over eager.
There is an option to add more than just MK7 golfs now... if that helps... (hmm maybe not on this forum lol)
VW Golf MK7 GTD Manual 5DR Pure White
Offline KyleB
« Reply #42 on: 25 January 2014, 15:50 »
Bit of feedback on the dimming indicators article it's not detailed enough mate. There are several other Leuchte2SL VLB10-Dimmwert and it doesn't indicate which one to change to 35.
Any ideas?
Offline noobmonkey
« Reply #43 on: 25 January 2014, 16:09 »
Heya, not sure what ya mean, as (Well i've not tried it though!)
  • Go to [09] Central Electronics
    Go to Security Access and enter 31347
    Go to adaptation channels and set the following (they're quite far down the list):
    "Leuchte2SL VLB10-Lichtfunktion G 2" to "Blinken links aktiv (beide Phasen)"
    "Leuchte2SL VLB10-Dimmwert" to 35
    "Leuchte2SL VLB10-Dimming Direction GH 2" to "minimize"
    "Leuchte3SL VRB21-Lichtfunktion G 3" to "Blinken rechts aktiv (beide Phasen)"
    "Leuchte3SL VRB21-Dimmwert GH 3 to 35"
    "Leuchte3SL VRB21-Dimming Direction GH 3" to "minimize"
Offline KyleB
« Reply #44 on: 25 January 2014, 16:12 »
When it tells you to change the option to 35 there are lots of other VLB-10 Dimmwert options (with different !letters at the end). Unlike the other steps, there is no indication which value you need to change to 35.
Other than that loving the site.
Offline noobmonkey
« Reply #45 on: 25 January 2014, 16:14 »
Ahhh ok!, Well they were all copied across, so may not have been checked yet :) - Off out - so if not checked by jive or equivalent will take a look tomorrow :)
I think quality of the data is always going to be questionable, as some people will never post all details etc. Hopefully the rest of can keep updating and adding correct information as we go :)
Offline jivemonkey
« Reply #46 on: 25 January 2014, 16:37 »
My bad, missed a bit out. Corrected now!
Offline KyleB
« Reply #47 on: 25 January 2014, 18:45 »
Cheers jive.
I'll happily add some Leon mk3 entries if you're interested?
Offline noobmonkey
« Reply #48 on: 25 January 2014, 19:14 »
Yes please! More the merrier :)
Leon MK3 added to the drop down :)
Offline jivemonkey
« Reply #49 on: 25 January 2014, 19:16 »
You're welcome, did you manage to get it all working okay? I'm thinking of lowering the dimming level to a bit lower.
Please do, the more we get on the site the better, even more so if they're tried and tested!
