Author Topic: Pre-Cat Removal on OEM Downpipe  (Read 17902 times)
Offline RocketRossUK
Re: Pre-Cat Removal on OEM Downpipe
« Reply #20 on: 21 January 2014, 08:56 »
So I will see gains on a standard car regardless ? if so, looks like im doing it on Saturday morning !!
Just be careful when removing the bolts to the turbo, due to the heat cycling they can become brittle and snap, requiring the remainder to be drilled out....complete pita and quite common.
Good point to bring up Raffe. Best thing to do is warm the engine for 5 mins and spray with WD40 or any decent penetration oil. Leave to coil and spray again. Then throughout the process keep squirting each bolt / nut and take it easy, dont ever go to heavy on the cranking. If you felt it getting really tight, back up and spray again.
Offline Hobojim
« Reply #21 on: 26 January 2014, 01:12 »
Will you be putting your car onto the dyno Ross?
« Reply #22 on: 26 January 2014, 11:09 »
Probably sometime in spring mate. Having revision 5 REVO stage 1, Revo stage 2 intake and Pre-Cat removed show be between 270-280 im hoping.
Offline Obbzi
« Reply #23 on: 26 January 2014, 22:47 »
With this mod what do you replace the pre-cat with? Or do you just "fettle" the existing pipe?
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
« Reply #24 on: 26 January 2014, 23:49 »
Yeah just knockout the precat out, then Fettle the pipe where is was. The 800 cel main cat stays as is.
