Author Topic: Timing belt covers  (Read 4706 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Timing belt covers
« Reply #10 on: 18 January 2014, 21:25 »
have 1 made in metal then powdercoat it  :smiley:
There's an idea it would be easy enough to make with metal if not powdercoated maybe anodised instead that would look  :cool:
2000 Mkiv GTi 1.8T AGU
Offline barrym381
« Reply #11 on: 18 January 2014, 21:28 »
or is there not a company that does a carbon dip to plastic trim  :smiley:
found it  :wink:
http://www.hydro-graffix.co.uk/#
« Last Edit: 18 January 2014, 21:32 by barrym381 »
Offline mcgee9t2
« Reply #12 on: 19 January 2014, 00:07 »
or wrap it ( I don't mean in the 3m stuff)
get a proper carbon wrapping kit.  usually contains a can of paint, one sheet of real carbon weave and one can of some kind of thick laquer type stuff.  spray an under coat of black paint, wait for it to go tacky, lay on the carbon weave, leave for a while  then add the top coat.
its the exact same process and stuff they use to make carbon parts, only they don't spray the black paint on (that's just to stop any white material underneath showing through) and they use many weaves to make the product thick, however you only need one weave cause your just wrapping the original product.
Offline dom
  • Back in a Mk4
« Reply #13 on: 19 January 2014, 11:08 »
^^^ That's a good idea but I'd guess it'll be hard to get it right.
found it  :wink:
The carbon dipping looks very good, I might get some of my interior parts done
Offline barrym381
« Reply #14 on: 19 January 2014, 11:20 »
found it  :wink:
seen old mike brewer getting it done on some range rover trim and it turned out great  :smiley:
Offline rockmonkey69
« Reply #15 on: 19 January 2014, 11:26 »
Can it be done to both sides of the cover so that it's seamless? I'm a bit padantic
Offline barrym381
« Reply #16 on: 19 January 2014, 11:39 »
its possible  :wink:
http://www.youtube.com/watch?v=mk4wzhTF-5c
  • "1.8T AGU"
« Reply #17 on: 19 January 2014, 18:48 »
Looks good  :cool:
Offline xtetx
« Reply #18 on: 19 January 2014, 20:33 »
Rockmonkey check out this guy:
http://www.c6carbon.com
He uses real carbon and skims over the item of choice. He does many interior / exterior items for many differnt cars. His work is second to non!
 :smiley:
Offline mcgee9t2
« Reply #19 on: 19 January 2014, 22:35 »
If this is the guy I think it is he lives over road from my mate and his work is spot on.
