Golf mk3
hardmonkeys
Stereo troubles
Topic: Stereo troubles (Read 7395 times)
JMK3
Re: Stereo troubles
Reply #20 on:
21 January 2014, 09:39 »
Quote from: itavaltalainen on 20 January 2014, 15:52
check them with a multimeter (£10), anything else is guessing
yeah, main though it the ignition switch though, sometimes when the cars running & the stereo wont come on then if i give the key a wiggle itll switch on
JMK3
Re: Stereo troubles
Reply #21 on:
21 January 2014, 12:48 »
I was also under the impression that it wasnt getting any power at times
because
of the faulty ignition switch? if power isnt getting to it the multimeter wont read anything
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Stereo troubles
Reply #22 on:
21 January 2014, 14:04 »
yeah but you can trace the wire back and check if it is the ignition switch or just poor contact somewhere or a broken wire
MereKat
GTI forum regular
Re: Stereo troubles
Reply #23 on:
21 January 2014, 14:46 »
If wiggling the key turns the radio on, id go with the switch.
xionsolaris
Here all the time
Re: Stereo troubles
Reply #24 on:
22 January 2014, 10:10 »
My stereo does not dimm on sidelights or switch on when i press it only works on aux feed but it dosent loose its memory
JMK3
Re: Stereo troubles
Reply #25 on:
27 January 2014, 15:14 »
Replaced the ignition switch yesterday. everything works a trea
MereKat
GTI forum regular
Re: Stereo troubles
Reply #26 on:
27 January 2014, 19:41 »
Good news
Golf mk3
hardmonkeys
Stereo troubles
