Author Topic: ABF 16V Oil cooler heat exchanger housing cleaned and ready to fit.  (Read 6035 times)
Offline Len
All 3 of my engines (2no. abf and one diesel) did not have any gasket there.
Ally bracket/housing straight to ally block.
For my own piece of mind I did put a smear of silicon on it.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Only seal I have used in that expanded view is 19
www.sas.org.uk
www.the-ace.org.uk
Offline Shizzle
i don't remember there being 1 tbh but a lot of work for a leak if i dont put one on.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Len
As I said none of the 3 engines had a gasket and there were no leaks!
www.sas.org.uk
www.the-ace.org.uk
It should have a gasket between block and housing, might be worth fitting a new exchanger as well at this stage.
Offline Shizzle
i have a good used one from last engine has no leaks and im replacing both seals to ensure no leaks as well.
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
The gasket has been present on all the VW/Audi passenger and industrial engines I have worked on That use the same housing and should be a single layer (possibly stainless) spring steel one. Because it usually sticks to the block not the housing it can be missed.
The only reason I can see a gasket is needed is due to the possibility of the housing warping and not sealing against the steel block.
New toy1990 Scirocco I feel a 16v conversion coming on.
Spot on, only real reason it is needed tbh.
Offline Shizzle
When i removed my housing last nigh it had a gasket on it .now replaced no leaks  :rolleyes:
Offline boneybradley
  • Back in a Mk3...
I should have these gaskets in stock by the weekend
(if anyone needs one, elring brand, price t.b.c)
