Author Topic: Dissapointing sat nav  (Read 18662 times)
Offline Mark V GTD
Re: Dissapointing sat nav
« Reply #10 on: 23 February 2014, 10:40 »
Gina - VW sat-nav units don't seperate postcodes from normal addresses. So you just carry on as normal but when it prompts you to type in the address town just type AB10 1XY or whatnot and it should recognise it...
Offline itavaltalainen
« Reply #11 on: 23 February 2014, 10:44 »
Just check the Navtec website here for updates, if the version number there is newer then update.
Easy as piss.... Download file from website, extract, copy to SD card... might wanna take copy of stuff that is already on the SD, then delete it.
Postcode search is easy, not sure why you're struggling so much?  :whistle:
(there was a bit of sarcasm towards VW there)
Tap 'New destination' -> tap the 'city/town' -> tap on bottom left where it says 'PSCD' or 'Pstcd' or something like that... it will then bring up a number pad (as continental postcodes are generally only numbers), tap the 'ABC' on bottom left, enter the 2 letters, tap '123' enter number, tap 'ABC' again to put the last characters....
Not sure why VW can't manage to get the software to start off with letters when the country is set to England, Wales, Scotland and Ireland.
Offline Mk1Macca
« Reply #12 on: 23 February 2014, 10:45 »
When you press address, there is a postcode button bottom left of the screen.
Annoyingly it brings up a number keyboard first, so you then have to switch to letters - but the functionality is there.
« Reply #13 on: 23 February 2014, 10:47 »
the vw one does ;)
Offline wigit
« Reply #14 on: 23 February 2014, 13:30 »
when i had a GTI on loan it had the normal rather than pro nav and i did not like it as in reality needed a quick session with the manual due to not twigging the postcode thing but loved all the other bits of it
Offline Mark V GTD
« Reply #15 on: 23 February 2014, 14:02 »
the vw one does ;)
I meant that is starts with 'address' rather than saying 'Where do want to go - an address, lat/long co-ordinates, postcode or a point on map...
You have to choose address before you can input a postcode.. ie; VW consider a postcode to be part of an address rather than a stand alone destination. Sorry for not explaining myself...
Offline Ginagee
« Reply #16 on: 23 February 2014, 14:42 »
Thank you muchly everyone, will give this a go. :grin: I've had the car nearly two months, but not yet looked at the manual - I haven't even begun to think about the cruise control! :whistle:
2014 GTi Mk7 5dr Manual, Reflex Silver, PP, DNS, Dynaudio, Pano Roof.
