Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47628 times)
Offline jivemonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #10 on: 09 January 2014, 08:54 »
Ok picked my car up to day and well happy with it ;-)
Any how can you give me quick step by step info of what you want me to do?
and I will go and do it now
Came across this when browsing the ross tech site..
http://www.youtube.com/watch?v=RCBt6d42-Fc#t=159
Is this the scan we're talking about? (haven't got my VCDS yet!)
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline jmc
« Reply #11 on: 09 January 2014, 10:42 »
Is this any good?
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011333702455
   Coding: 03000A42C24122FB0BA44080B10C07281000000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7BF1B049F2A6D0C6C11-802E
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    131121  042 0551
   Serial number:         131123070344
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M12D05H09M06S27S9
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY13302414R
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000058181743
VW Golf VII, GTD, manual, Night Blue, Rear view camera.
Offline jivemonkey
« Reply #12 on: 09 January 2014, 11:33 »
It looks pretty good, but not sure how we approach decoding what you have provided? Any idea Mark?
I thought we needed some sort of door controller module? My VCDS will arrive tomorrow so can investigate the Pre-BW45 at least!
Edit.
Just had a quick look on the VCDS manual. JMC, when doing the scan, did it give results for controllers 42 and 52? These are apparently the driver/ passenger door electrics controllers. I wonder if this is where we need to look?
Good effort!
« Last Edit: 09 January 2014, 11:41 by jivemonkey »
Offline noobmonkey
« Reply #13 on: 09 January 2014, 11:46 »
when i get home tonight i can post a quick screenshot guide on how to get to the screen (If someone's not got there before me)
VW Golf MK7 GTD Manual 5DR Pure White
Offline jmc
« Reply #14 on: 09 January 2014, 11:47 »
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 24111306070085
   Coding: 003F0220D001048000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 408B07A5DBC0731ED43-8015
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000003580213
   Coding: 0D0000
No fault code found.
Offline jmc
« Reply #15 on: 09 January 2014, 11:48 »
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 19111304080721
   Coding: 003F0020DE01048000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 3F890459A63E0CE6AD9-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000003560385
   Coding: 050000
No fault code found
Offline noobmonkey
« Reply #16 on: 09 January 2014, 11:50 »
ahhh that looks good!
Offline jivemonkey
« Reply #17 on: 09 January 2014, 12:18 »
Very good indeed!
Having had a quick offline poke around VCDS, am I right in saying that there aren't any labels for the 42/52 door controllers? I can find the 5Q09 label for the central electrics module but no such luck for the doors.
Offline Mark V GTD
« Reply #18 on: 09 January 2014, 17:53 »
This is all good stuff - a step closer to figuring this out...
I'm wondering if (assuming the coding is different on the door modules post BW45) that the new code can be simply substituted for the old one?
« Last Edit: 09 January 2014, 17:56 by Mark V GTD »
Offline Mark V GTD
« Reply #19 on: 09 January 2014, 17:59 »
These are definately the components that control the door mirror functions - I know from the many posts in the Scirocco forums about substituting folding mirros for non folding ones - the last part of the job is to change the codes in those two controllers....
