Author Topic: DIY turbo inlet pipe  (Read 6016 times)
Offline Chris.
Re: DIY turbo inlet pipe
« Reply #20 on: 09 January 2014, 01:29 »
heres mine
Click For Build Thread
Offline Dave_IOW
« Reply #21 on: 11 January 2014, 11:31 »
Very much like that Chris, but with a silicone reducer straight off the turbo, then an alloy bend I'm thinking to meet up with top part of a silicone TIP I have.
Where's your DV and N75 port?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Chris.
« Reply #22 on: 11 January 2014, 20:02 »
Dump valve is that pipe off the middle of the pipe.
No N75 port as the spare port is venting to atmosphere.
Depending on turbo, there isnt much space near the linkages....hence I had to do a 2 step reduction from 45-63mm then 63-76mm
Offline Dave_IOW
« Reply #23 on: 11 January 2014, 21:23 »
My linkages are probably in a slightly different positioning to yours, mines in a mk2 shell.
The main thing I'm trying to do is move the part that runs vertically away from the compressor housing to allow more room for IC piping.
Offline slimwadey
« Reply #24 on: 04 July 2014, 22:48 »
Any more news on this pipe ??
I'm considering doing something similar and like the idea of the ally converter but don't have a local machine shop
So I guess the best way is to use a reducer from turbo up to a large size ally pipe
I'm nearly done installing my 20v into my mk2
Offline snail_on_skunk
  • MK3 Golf GTI 20VT
« Reply #25 on: 05 August 2014, 20:09 »
thought id show you guys what i had made for my K04 hybrid the other day, moved jobs opposite a machine shop and they done this for me in exchange for servicing his car
its now 2 1/2 inch so straight from there gonna put silicone pipe going up to 3" and straight to 3" MAF, couldnt go straight to 3" cause ABS unit is in the way, ill post up pics when fully installed
6N2 Polo 1.4 8v
Mk3 Golf GTi 8v
Mk3 Golf GTi 20VT
