Author Topic: 1.6 using oil  (Read 1291 times)
Offline vw_golf_nutter
1.6 using oil
« on: 31 December 2013, 13:39 »
hi, i was going to look at a 1.6 2000 Golf tomorrow but the lady has just mentioned she has to top it up with oil fairly regularly. she said it isnt leaking as theres no puddle on the drive just the light comes on and she tops it up?! dont think she knows a lot but to be honest I dont really know what this would mean.
Should I avoid it?
thanks
Offline gazareth
Re: 1.6 using oil
« Reply #1 on: 31 December 2013, 17:24 »
I would say steer clear and keep looking.
Offline northeast_gti-t
  • "1.8T AGU"
Re: 1.6 using oil
« Reply #2 on: 31 December 2013, 17:30 »
Should I avoid it?
thanks
:shocked: Not the best of ideas relying on the low oil warning light to tell you that the oil is low as this can often start to cause damage due to a lower pressure  :sad: look for signs of blue smoke after initial start up/warm up period   and once warm try a stretch of downhill road (if possible) and let your foot off the acc pedal,once level again give it a tap on the throttle and look for signs of blue smoke on the over run pointing to possible valve stem oil seals worn or valve guides worn a comp test will point to piston ring/bore wear done wet and dry also the spark plugs will be wet and oily,if your after a 1.6 tbh theres a few about i personally would avoid this one  :wink: hth
2000 Mkiv GTi 1.8T AGU
Offline xxChrisxx
Re: 1.6 using oil
« Reply #3 on: 31 December 2013, 17:31 »
Wow. Repeatedly driven until the oil light comes on.
This would mean the engine
A: is very close to bring irreparably f**ked.
B: is f**ked already.
Avoid  :wink:
Re: 1.6 using oil
« Reply #4 on: 31 December 2013, 18:02 »
As posted leave it well alone.
