Author Topic: Clutch pedal snapped.  (Read 3187 times)
Offline mcgee9t2
Re: Clutch pedal snapped.
« Reply #10 on: 28 December 2013, 13:57 »
anyone know if theres a clutch cylinder bleed valve to relieve some of the pressure in the master cylinder and if so where?
Offline mcgee9t2
« Reply #11 on: 28 December 2013, 14:39 »
or should I be able to push the master cylinder in by hand? not sure if iv bent/broke it and that's why I cannot push it in or whether its just the pressure in the cylinder?
Offline Bellend
« Reply #12 on: 28 December 2013, 14:51 »
It would be quite difficult to push in by hand mate. What's the issue?
Where all my moneys went.
Offline mcgee9t2
« Reply #13 on: 28 December 2013, 15:57 »
cant quite get the pedal in cause the master cylinder push rod is in the way.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 28 December 2013, 16:50 »
chop it down, it'll be fine :laugh:
Offline mcgee9t2
« Reply #15 on: 28 December 2013, 16:54 »
soon as I saw your username I though oh Wes he will have a sensible reply and be able to help... How wrong I was  :grin:
Offline Bellend
« Reply #16 on: 28 December 2013, 18:30 »
Suppose it would be difficult without a picture.
Sure it's in properly? Would it be at the correct distance if you could get it in? IIRC it's like a kind of box shape which the rod slots into?
If the length is in the correct place but doesn't allow the pedal to get into the box then just take it out and line it up and bolt back up.
You don't really want pressure on the rod when pedal is in relaxed position as it's just asking for unnecessary component wear.
Offline mcgee9t2
« Reply #17 on: 28 December 2013, 18:58 »
Prober boy just me, it's a bit of an awkward bugger. Will have a go tomorrow again and if no joy upload a few pics.
Offline mcgee9t2
« Reply #18 on: 29 December 2013, 15:46 »
Sorted. Cause I had the plastic clip on I couldn't position the pedal to get the piston in. Soon as I took the clip off sorted. PITA  of a job though. If it snaps again I'll take a wv bill over ripped open / bruised hands.
Also. If you drip a clutch pedal, make sure the pointy end doesn't land on your eye...one of the most painful things
Offline mcgee9t2
« Reply #19 on: 29 December 2013, 16:25 »
Got it sorted. Works and that. However when I dip the clutch I get a weird high pitched noise. Any ideas anyone
