Author Topic: Brake lines for Cupra R Brembos  (Read 5237 times)
Offline Winniee
Re: Brake lines for Cupra R Brembos
« Reply #10 on: 25 December 2013, 11:03 »
I've just done exactly what you've done. Painted my brembo's blue. Just waiting on stickers. I went for some goodridge phantom braided lines. Your standard lines will be too short on full lock. As for rear brakes, why not go for the leon cupra r ones to match the fronts? The discs are only slightly bigger but theyre vented plus you'll be sticking with an oem bias, albeit for a lcr. No point going too big as your rears only account for about 30% of the total braking effort.
Can you link me to goodridge lines?
Also would this kit be worth getting? I also get braided lines with it then:
http://www.ebay.co.uk/itm/221158275237?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The backs aren't brembos though are they? Just grooved disks?
GolfGTIForum Build Thread -
http://www.golfgtiforum.co.uk/index.php?topic=263142.0
Something breaks? Upgrade it!
Offline Winniee
« Reply #11 on: 25 December 2013, 12:20 »
Found a set of rear leon cupra r brakes. Are they vented?
Offline beppe2672
« Reply #12 on: 25 December 2013, 12:24 »
The lcr rears are just normal calipers. But they 256mm vented discs as apposed to the 232mm solid discs we get as standard. I got the hoses from demon tweeks, cant remember how much they were but I got fronts and rears.
 That kit you linked is just a rebuild kit, body bolts, shim bolts and the link pipe that goes between the 2 halfs of the caliper.  Is it the solid section of pipe that comes out of the back of the caliper that you're after? Think you might have to go to the dealers for that.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Winniee
« Reply #13 on: 25 December 2013, 12:36 »
That's what I need that was broken and need the brake hoses aswell.
£100 collected I got him down to on the back brakes? Sounds alright to me.
Offline beppe2672
« Reply #14 on: 25 December 2013, 12:56 »
You could try and get some made? the threads are M10x1.0. Or go to the dealers.
Offline Winniee
« Reply #15 on: 25 December 2013, 12:59 »
Im guessing the ones in the service kit for them isnt the right set if lines then?
Offline beppe2672
« Reply #16 on: 25 December 2013, 14:38 »
Just had a look around, from what I can see Hel brake lines would do the job. Give them a bell and ask if they could supply the lines with a 90 degree elbow and a m10x1.0 male thread on one end.
Offline dom
  • Back in a Mk4
« Reply #17 on: 25 December 2013, 17:26 »
Just got my brakes back and well impressed after I've put my stickers on:
You've put one of the stickers on upside down :whistle:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 25 December 2013, 18:17 »
rear brakes on the Cupra R are the same as the Cupra, Anniversary and Skoda Octavia vRS.
DaveyB on ukmkivs did a 286mm kit for the rear using the 256mm caliper, it looks massive!
Offline barrym381
« Reply #19 on: 25 December 2013, 21:13 »
its meant to be 302mm on the rear of mine will measure then to be sure  :wink:
