Author Topic: *Sh!t and balls! Rear drivers calliper looks to be leaking HELP Needed Please!!!  (Read 3873 times)
Offline monzablue16v
Re: Sh!t and balls! Rear drivers calliper looks to be leaking
« Reply #10 on: 26 August 2005, 11:46 »
Right going to get mk3 callipers in an hour or two. Need to know what is the difference between my mk2 ~(88) rear callipers pads hoses and discs and a mk3 calliper and bits?  Also what am I going to need to buy from GSF to fit it all tonight? as I can't go back for bits once I start  :) cheers guys
Discs are same, but later MK3 calipers have thicker discs.  The later calipers are the ones you want btw cos early MK3 calipers are the same as MK2 items!
Right been and got a new mk2 rear calliper as they only had 1 definitley good mk3 calliper in. I have had one of those thoughts I remember hearing that the rear callipers are 2 line and there is only one hole on the calliper I have can't eve see the hose it's that low!!........... have I dropped a clanger???????
Judderi
Mines only 1 line.
thank fook 4 that :D :D :D :D
