Author Topic: BBS wheel size  (Read 4573 times)
Offline caprigreen
Re: BBS wheel size
« Reply #10 on: 18 December 2013, 14:56 »
Hello Steve,
Is your car a 1991 or a 1992 model year?
Is there an M or an N in the chassis number before the W at the end before the numbers?
I presume a 1991 as back then the model years started in the October of the previous year.
If this is the case then 14" steelies were stock on the 8v.
Wheels were dealer fit options in those days and there was an Accessories brochure that listed what you could have.
15" BBS RA were never available from new for the 8v until they became standard for the 1992 model year run-out cars.
The fire extinguisher clipped to the seat mounting point of the passenger seat, limited life so anything truly correct will be out of date by now but understand why you need one.
Mudflaps would have been non-tailored and some usually came with little badges that clipped on.
Andrew
Hi Andrew,
Thanks for the information.
My car was registered in June 91 with a M before the numbers on the chassis number.
Not too worried about the fire extinguisher.
I have been trying to find a set of votex mudflaps new old stock but from what you say these were not likely to be the ones fitted in 91. I have looked at the plastic arches and there are no obvious marks suggesting mudflaps have been fitted.
I have obtained a first aid kit and warning triangle.
Car also has electric aerial and rear headrests which is also unusual.
Steve
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
