Author Topic: Vancouver width??  (Read 3226 times)
Offline Mattyj
Vancouver width??
« on: 13 December 2013, 14:27 »
Hi seen it recently but can't find it now :( standard width of vancouvers?
Offline dubber36
Re: Vancouver width??
« Reply #1 on: 13 December 2013, 14:35 »
7.5"  :smiley:
Offline Mattyj
« Reply #2 on: 13 December 2013, 14:39 »
Cheers got a se of 8.5's just trying to work out best tyre size
Offline dubber36
« Reply #3 on: 13 December 2013, 15:28 »
What offset are the new wheels?
Offline Mattyj
« Reply #4 on: 13 December 2013, 16:28 »
Can't remember off hand test fitted tho and they are fine
Offline Mattyj
« Reply #5 on: 13 December 2013, 16:29 »
Et44
Offline dubber36
« Reply #6 on: 13 December 2013, 16:39 »
Those wheels will poke 19.7mm more than the Vancouvers and be 5.7mm closer to the suspension on the inside.
If you want a bit of stretch then 225-40's should be fine, but my preference would be 235-40, as that will give a more upright side wall. It all depends how low you are going and how much outer arch clearance you need.
Offline Mattyj
« Reply #7 on: 13 December 2013, 16:44 »
Arch clearance with right height is not a problem as its going on air so just want them to tuck when on the floor if they don't they don't i'll come up with something i was looking at 225/40/18 they came with 245's HUGE!
Offline mark@vorny.co.uk
« Reply #8 on: 13 December 2013, 17:37 »
235's fit an 8.5" rim perfectly. I had a BMW in the past with 8.5" rims on the front, initially ran 225's which looked stretched, but that extra 10mm up to a 235 made them perfect  :smiley:
2012 GTi 3 door, DSG, Nav, Roof, Monza's. Candy White..... and it's the wife's.
2013 Abarth 595, 2013 911 C4S.
Offline Mattyj
« Reply #9 on: 13 December 2013, 18:07 »
How perfect? I like a touch of stretch
