Author Topic: Looks like a few lowering spring options are on the way!!  (Read 11312 times)
Offline GrahamFR
Re: Looks like a few lowering spring options are on the way!!
« Reply #10 on: 10 December 2013, 09:39 »
do the dampers not change the level of travel in the springs?
And why are there two part numbers for the same springs if it makes no difference?
http://www.dcperformance.co.uk/cheap/790623/volkswagen/eibach-pro-kit-springs/e10-15-021-02-22.html
http://www.dcperformance.co.uk/cheap/790625/volkswagen/eibach-pro-kit-springs/e10-15-021-04-22.html
OK ive done some reading and decided my response now is 'feck knows', but im just more comfortable with a spring that states specifically that it works with ACC, like the vwr ones
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline kevinm
« Reply #11 on: 10 December 2013, 09:50 »
Suspension Levelling Control is not ACC. That is the system in some cars, usually estates that can raise the rear suspension when carrying heavy loads to level the car.
That remark is on all the kits on eibach's website. It even says it for the ED30 and there was no ACC back then.
The -04-22 kit is for the beam rear axel which is the lower powered mk7's. The only kit listed for the GTI on eibach's own website is the -02-22
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline kevinm
« Reply #12 on: 10 December 2013, 09:54 »
My only concern would be the front axle weight. For older GTI's, eibach do 2 versions of each kit. One is for a higher front axle load. My guess is that means DSG cars.
My car will have a high front axle weight due to the DSG and PP. I wonder if Eibach will make a second version for these mk7's or will one kit now do all specs of GTI?
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline GrahamFR
« Reply #13 on: 10 December 2013, 10:03 »
ahh i see, ok well that makes more sense then. In relation to the weight question, does the current DSG box weigh the same as it did on the older mks? Maybe the difference isnt as bad anymore and therefore doesnt require two different springs
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline kevinm
« Reply #14 on: 10 December 2013, 14:37 »
Ok so I had a look at the GTI axle weights:
DSG adds 20kg just to the front axle
PP adds 30kg as 20kg to the front and 10kg to the back
So max axle load for a PP DSG (heaviest configuration) is:
Front: 1040kg
Rear: 880kg
That's under the max load for the eibachs which is:
Front: 1070kg
Rear: 1000kg
I'd say you're right Graham, it looks like one spring set for all versions of GTI.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline GrahamFR
« Reply #15 on: 10 December 2013, 14:59 »
wow I didnt realise it would add such weight, i take it thats the ediff?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline kevinm
« Reply #16 on: 10 December 2013, 15:28 »
I'd say most of it is the bigger brakes. The 10kg extra on the back can only be the rear brakes so I'd assume a similar increase for the front brakes.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline GrahamFR
« Reply #17 on: 10 December 2013, 15:55 »
Ive always been curious about the brakes, can you see the sizes on etka? I didnt realise the PP beefed up the backs as well
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline 2014GTi
  • Das Auto
« Reply #18 on: 10 December 2013, 16:34 »
The Golf GTi Performance Pack has the same brake setup like the Golf R ;)
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline kevinm
« Reply #19 on: 10 December 2013, 17:36 »
340mm front and 310mm rear, both vented. I fitted 345mm mk6 R brakes to my ED30 and I could not get over how much heavier they were than the standard 312mm GTI front brakes.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
