Author Topic: Golf Mk3 1.8 ´96 AAM Estate - Location of the crankcase breathing system?  (Read 7708 times)
Offline itavaltalainen
you can buy the throttle actuator, but not individual parts (like gears) - new aftermarket probably around 50€
after replacing you may need to run through the alignment procedure with vcds
Offline golfrace
.....my speedo shows 250 000 yes :)
Offline Jasikasisback
great post
Offline golfrace
You know how to reset ECU from dashboard? :)
you can't. dashboard on mk3 has no direct link to ECU where it can communicate anything back.
you will need vcds if you want to do anything to the ecu. that connects to the OBD 1.5 connector next to ash tray, but you will need the correct cable and vcds lite.
Offline gazareth
Is this a car we are talking about? :huh:
no, dogging  :rolleyes:
fixed the problem?
