Author Topic: Leather Recaro Heated seat fix?!?  (Read 7682 times)
Offline markymarkg
Re: Leather Recaro Heated seat fix?!?
« Reply #10 on: 07 December 2013, 23:29 »
Been in touch with the guy at VW Teeside and he says thy should fit but may need some adjustment?!?
I'm gonna PM Matt to see if he knows anything about the part no's.
Offline Nino
  • Insta - F6UGA
« Reply #11 on: 08 December 2013, 09:11 »
I just installed my loom and I think the element in my seats are gone as I can only feel the lower back heating up  :angry:
Anyhoo I came across this so hope it helps :)
http://uk-mkivs.net/topic/8693-heated-seat-elementreplacement-with-pics/
Current - MK6 GTi Edition 35
Offline markymarkg
« Reply #12 on: 08 December 2013, 16:37 »
I think the upper element is piggy backed off the lower element so if the lower stops working the upper should as well...i think?!?
Yeah, i've seen this and several others but apparently the leather Recaro is different. I was wondering if anybody had changed the element in this make/model of seat or you can fit a normal element!
Offline Nino
  • Insta - F6UGA
« Reply #13 on: 08 December 2013, 22:27 »
Yeah mine are leather to
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #14 on: 08 December 2013, 22:57 »
The leather and cloth Recaros are the same shape so I don't see how the elements can differ
Offline sharki786
  • GOT BOOST??
« Reply #15 on: 09 December 2013, 07:39 »
You have 2 types of leather seats. The recaros and the non recaros. Maybe thats where the difference is? Stripping the seats apart is easy. I did my mk3 anni seats and it was dead easy
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Nino
  • Insta - F6UGA
« Reply #16 on: 09 December 2013, 12:27 »
Id assume that the RECARO cloth or leather would be the same?  :huh:
Offline markymarkg
« Reply #17 on: 09 December 2013, 12:57 »
Apparently, the difference is that the element is stitched in to the actual leather and padding and not glued onto the seat base foam.
I'm going to try and strip it this week to have a look and see if this is the case.I may try and jump the burned out section with a piece of wire first if it can't be removed from the actual seat.
I know its not a golf seat, but you get the gist!
http://forums.bimmerforums.com/forum/showthread.php?1165042-Heated-seat-repair-done!-DIY
Offline Nino
  • Insta - F6UGA
« Reply #18 on: 09 December 2013, 15:14 »
Well my back and the leg parts seem to heat up but that's it lol
Offline sharki786
  • GOT BOOST??
« Reply #19 on: 09 December 2013, 18:31 »
That seems abit risky to me. Literally your arse on fire!!
*****MK4 GTI T*****
