Author Topic: My mk4 Golf Gti 1.8t  (Read 29211 times)
Offline Carl!
Re: My mk4 Golf Gti 1.8t
« Reply #10 on: 18 January 2014, 16:00 »
Cheers Barry. replaced thermostat other day, added a tt clutch pedal as I was missing that buy to getting conned!
and did the n249 bypass. before;
after;
« Last Edit: 29 January 2014, 18:57 by Carl! »
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 18 January 2014, 16:06 »
Nice car mate.
I tried to do my track rod ends but they were seized on so it had to go to a garage in the end.  Remember once you've replaced them you need a wheel alignment doing.
Offline Carl!
« Reply #12 on: 18 January 2014, 16:11 »
cheers bob. did the track rod ends the other week, mine came off nice and easy for a change!found somewhere local with laser wheel alignment too as my mates garage couldnt do it.
Offline dom
  • Back in a Mk4
« Reply #13 on: 18 January 2014, 16:40 »
Out of interest, where did you use for alignment?
Offline Carl!
« Reply #14 on: 18 January 2014, 17:12 »
quick fit, one near the town centre of Barnsley on racecommon road.. theyve got laser alignment jobbie.
Offline Carl!
« Reply #15 on: 25 January 2014, 17:10 »
birthday present fitted. also fitted some blue vision headlight bulbs. need a new gearknob as that cheap ebay one isnt smooth.
Offline Carl!
« Reply #16 on: 31 January 2014, 14:31 »
Water pump went wednesday! gutted as id had cambelt done about 8month ago so messed up not changing pump then so quite a dear mistake! Also had a flat so bought an eagle f1. Ive raised the car a bit to stop it rubbing on the drive shaft and at the back and and gave it a quick wash.
ive got bora vents to fit when I get round to looking at the wiring(looks harder than I expected)  and also waiting on a few net optic bits so I can go for the ali look around the stereo as my carbon fibre efforts are better than wood but not really doing it for me.
Offline Carl!
« Reply #17 on: 01 February 2014, 23:43 »
something cut a hole into I side of my right hand rear tyre so I've raised the car slightly,  a lot less scrape type noises going off now which is nice!
Offline Carl!
« Reply #18 on: 04 February 2014, 18:10 »
I can't recommend these guys enough and the stage 1 map is essential, I joked and said I might put the gti badge back on now it feels like a gti. Top top lads and a top service.
Offline Carl!
« Reply #19 on: 05 February 2014, 19:18 »
bought some bora sport clocks without checking first and mines an immo3 and they are immo2, assumed id be right with mine looking a lot more dated  :cry:
