Author Topic: Front left brake still sticking after replacement  (Read 3043 times)
Offline madsb
Re: Front left brake still sticking after replacement
« Reply #10 on: 02 December 2013, 17:33 »
Had the hose changed but no difference.. So what could it be? : Slide pins, rust on piston and bad tracking?.. Thinking the latter is more likely, as I assume the mechanic has checked the two first things.. Any input?
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 02 December 2013, 21:30 »
get it to an m.o.t place and get the brakes rolling tested, this will tell you what both sides are doing effort wise (and brake balance)
that will/should tell you if it's a brake issue.
Have you checked the rear brakes?? (these are more prone to sticking)
