Author Topic: HELP Tracking Wheel Alignment Problems  (Read 3886 times)
Offline Shizzle
« on: 26 November 2013, 11:46 »
Im having Tracking/Wheel Alignment Problems.
My car is to low and front tyres to thin and rear wheels to wide compared to front.
We have a 4 wheel alignment machine with 4 lazer/sensor things that go on each wheel, 1st problem was to low and when on lock the sensors hit the ramp so we took the spacers off  the machine and then when starting alignment on lock either way lost signal to the rears  and said machine was incorrectly set up.
Next thing went to national tyres 5 min walk from house they said bring it down no luck again as arch/tyre gap is less than an inch making it to difficult to get aligning tools on.
So what can i do im thinking of doing it myself by measuring the inner wheel on the front and back making sure the distance is equal,making the wheels point straight then some toe in on the front as most front wheel drive cars do this and are not completely straight.
Does any 1 else have a good idea of diy alignment.
« Last Edit: 26 November 2013, 12:07 by Shizzle »
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Shizzle
Re: HELP Tracking Wheel Alignment Problems
« Reply #1 on: 26 November 2013, 14:42 »
No One :undecided:
Offline GOLF-MK3-GTI
« Reply #2 on: 26 November 2013, 15:22 »
You cannot track rears up on the MK3 as it's a solid beam.
You can only do the fronts. Have you tried aline in Dudley?
Offline Shizzle
« Reply #3 on: 26 November 2013, 15:31 »
not tracking the rears just the machine we use takes a alignment from rear wheels but not in my case as they are wider.
Im in bedfordshire that's just a little to far for me.
Need a garage that does old school string alignments lol.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 26 November 2013, 18:29 »
Find somewhere with a Hunter proalign system, they can do pretty much any geometry setting on most cars very accurately.  It'll cost you at least £70 though depending on the amount of adjustments required eg. camber, caster, thrust angle, toe etc.
Offline tweed
« Reply #5 on: 26 November 2013, 19:02 »
No old wheels to put on or borrow?
You can do it with the string and measure method. Google that up.
Offline tweed
« Reply #6 on: 26 November 2013, 19:03 »
Or raise it a inch or two then lower back down.
« Reply #7 on: 26 November 2013, 19:51 »
The geometry will change though therefore defeating the object of going in the first place.
« Reply #8 on: 26 November 2013, 19:53 »
How about chucking some old narrow steel rims or even space savers on whilst its been set up?
Offline Shizzle
« Reply #9 on: 26 November 2013, 21:49 »
The problem I have is its so low my other wheels also 15" have alot larger tyres making it more difficult to use any thing that hook on the tyres for an alignment I will deffo google the string idea need something old school.
