Author Topic: Thinking of buying this, what you think guys?  (Read 5659 times)
Offline Nino
Re: Thinking of buying this, what you think guys?
« Reply #10 on: 28 November 2013, 21:45 »
OK taken a look at it now and I must say I am impressed, furthermore just looking at the loom kind of explains how it works
Luckily I already have the switches and I also have the blocks that plug into the seats themselves.
The loom starting at the switch end splits off for the two switches see below...
Abit further down it leads to what looks to me like an earth wire and two live wires 1 of which has the relay and the other has a fuse (im yet to work out where this goes).
It then splits off at the otherend to go to each seat as said earlyer im lucky as I have the blocks from when I got the seats.
Now all I have to do is work out which wire connects to what :)
Hope this helps mate.
« Last Edit: 28 November 2013, 21:48 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 28 November 2013, 22:33 »
You need a switched and permanent live I think
Offline Nino
« Reply #12 on: 28 November 2013, 22:34 »
Yeah need to work it out
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 29 November 2013, 19:32 »
Which one has no end connector?
Offline Nino
« Reply #14 on: 29 November 2013, 21:10 »
What you mean Wazz?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #15 on: 29 November 2013, 22:46 »
it says one of the red cables should have no end connector on it?
Offline Nino
« Reply #16 on: 29 November 2013, 22:56 »
Arh yes this is the one that is off the fuse.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #17 on: 29 November 2013, 23:04 »
fused to ignition live then, there's a nice yellow terminal that will do the job under the dash plastics and also a red terminal to run the permanent live to :afro:
I'd still fuse the permanent one though...
Offline Nino
« Reply #18 on: 30 November 2013, 00:48 »
Arrrrh brilliant, its one of those that without seeing what you mean I wont see it will I lol
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
« Reply #19 on: 30 November 2013, 23:19 »
I need a loom for my heated Recaros, this loom look fit for the job?
http://www.ebay.co.uk/itm/221239032205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Seen these on ebay for £39.99 I already have the switches and the sections that plug into the seats but nothing else.
The guy sent me the instructions so i could take a look... i however and looking and thinking  :huh:
Hey Nino you managed to get it all working yet dude ??? Gona get the same kit if yours has fitted spot on  :smiley:
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
