Author Topic: Wheel/Suspension Concerns after driver forced me off the road.  (Read 6240 times)
Offline Ginagee
Re: Wheel/Suspension Concerns after driver forced me off the road.
« Reply #10 on: 22 November 2013, 13:18 »
I was driving along a country winding lane about 50mph
Try 30mph next time Gina  :wink:
Ha ha! Wot, 30mph on a derestricted road? Me? NEVER!!!!  :grin:
2014 GTi Mk7 5dr Manual, Reflex Silver, PP, DNS, Dynaudio, Pano Roof.
Offline Mr Savage
« Reply #11 on: 22 November 2013, 15:49 »
There is indeed Ginagee and thank you! :)
Car checked and thankfully all is fine! The front camber is off by about .11 on the drivers side which wasn't the side of the impact which the mechanic said was very strange as VW wouldn't have set it up like that from factory and you can't adjust it on the Mk7.
He was thinking it's possibly a manufacturing fault. Going to keep an eye on it to see if I get inner edge tyre wear/rub and if I do then it's going back to the dealers as this will be warranty covered.
When you say the camber is off by 0.11 (I assume degrees) this is not ideal but should not cause a problem with premature tyre wear and I'd be surprised if you'd notice it in the handling - and you state that the car feels fine.
Camber in itself, unless it is excessive, isn't too bad for tyre wear... excessive camber in conjunction with toe (especially toe-out) will wear tyres very quickly... but keep and eye on it
It was off by 1.13 originally then adjusting the rest also adjusted that down to 1.11 so when I say out by 0.11 I mean over VW's maximum recommended guidelines of 1.0 (Ideally 0)
The car drives fine as this is of course not noticeable. I'll have a check of the tyre in another thousand miles or so and if I'm getting uneven wear it's back to VW!
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline corgi
« Reply #12 on: 22 November 2013, 16:04 »
I see, so by adjusting, the toe (or castor if it is adjustable on the Golf) they could bring the camber back into line (or close enough).
Most modern cars run a bit of -ve camber - my 911 runs a some negative camber ~ -1 degree and I have no wear problems. When I first bought it it was running > -2 degrees that along with a load of toe-out (I don't know why it had been set up like that) meant I rooted a pair of front tyres in less than 10K miles the main culprit being the toe-out... the replacement fronts have lasted well in excess of 20K... So, as I said, keep an eye on it but I don't expect you'll experience problems.
Corgi
