Author Topic: MK3 Golf 16v piston height engine is not well  (Read 6110 times)
Offline Len
Re: MK3 Golf 16v piston height engine is not well
« Reply #20 on: 19 November 2013, 13:18 »
But if the bores are scored then forget and get a new engine.
www.sas.org.uk
www.the-ace.org.uk
Offline spikenipple
« Reply #21 on: 19 November 2013, 16:57 »
Or bore it out  :evil:
Offline ant_gti
  • mk3 20v turbo
« Reply #22 on: 19 November 2013, 18:36 »
Then bolt a turbo on  :whistle:
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
« Reply #23 on: 19 November 2013, 20:26 »
Thank you for all the offers for parts and engines, I will remove the sump and pistons on Saturday and let you know what I find.
New toy1990 Scirocco I feel a 16v conversion coming on.
Offline chris_d66
« Reply #24 on: 24 November 2013, 17:58 »
Hi All
Took the sump off today and removed pistons 1 and 4 big end shells good, number 3 top shell cracked bottom ok, but number 2 top shell paper thin and bottom shell cracked all crank diameters the same except 2 which is scored to be fair they are not that deep but the crank will need a regrind or replacing.
The Block is now out of the golf so tomorrow I will remove the crank and check to see what condition the crank cups and shells are in.
So far number 2 will need another rod, crank will need a regrind or replacing + new shells and rings.
Offline Len
« Reply #25 on: 25 November 2013, 12:32 »
How near to me are you?
Because I have a spare crank for you as well as good pistons and rods!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #26 on: 02 December 2013, 10:54 »
Was good to be of assistance mate! :afro:
www.sas.org.uk
www.the-ace.org.uk
