Author Topic: Advice please!!!  (Read 3390 times)
Offline matty1664
Re: Advice please!!!
« Reply #10 on: 15 November 2013, 19:02 »
cool, thanks for all the advice guys! Much appreciated!! I will let you know what I end up doing and what the outcome is!
Matt
« Reply #11 on: 16 November 2013, 00:15 »
I would stick with standard valves, £1000 is madness.
« Last Edit: 16 November 2013, 23:45 by Wayne »
Offline clipperjay
« Reply #12 on: 16 November 2013, 01:26 »
Valves have to fit the port work  :wink:
Offline danny_p
« Reply #13 on: 16 November 2013, 18:50 »
big valves giveing 30 BHP     LOL
valves in the 8v head are plenty big enough,   if you just duff bigger valves in a standard / standard ish head it'll usally make less power.
i would ask them to provide before and after flowbech readings for other heads of the same spec they have done,  and if you have your head done flowbench readings for it before and after.
i would go with new guides  cut back and taperd, reshape and polish the valve back  then have the valves and seats TRi cut with 30 degree seating face about 60 tho / 1.5 mm  thick,    deshrouded the valves as much as possible and match the ports to manifolds and a 16v downpipe.    that should make it a bit fitter
all the VW's have gone bar 1.
