Author Topic: EA288 2.0 TDI 184PS Development thread..  (Read 189886 times)
Offline monkeyhanger
Re: EA288 2.0 TDI 184PS Development thread..
« Reply #80 on: 20 March 2014, 09:58 »
Andrew,
Does 3+1 have less of a signal modification than 4+1 across the “map” (and presumably being more efficient through lower fuel usage at any given output), or is the shape of the “map” just slightly different? I have just filled up my car, so I’ll give it a tank’s run on 3+1 and see what I get.
Looking at the 2 dynos, the 4+1 has marginal power gains over 3+1 to 2400rpm (but with almost identical torque development from 2000-2500rpm). That is reversed from 2500rpm to 4000rpm, where the 3+1 edges it in both power and torque right through said range.
Offline Andrew@DTUK
« Reply #81 on: 20 March 2014, 10:09 »
Andrew,
Did i give you some coloured graphs with the kit?
Are you looking to tune your Golf GTI or GTD? Were currently offering members £80 off the full RRP on all DTUK Petrol and Diesel Tuning Systems.
PM me for the discount code
« Reply #82 on: 20 March 2014, 12:26 »
I'm sure they were in the box (I remember seeing them), but the box is now up in the loft so i'd have to dig it out. I thought it might be a case of asking what the voltage increases were on your maps for both 3+1 and 4+1, then make the assumption that if 3+1 has a lower voltage increase across the range then it should be fuelling less than 4+1. Either way i'll give 3+1 a go when I get home tonight.
Offline Andrew@DTUK
« Reply #83 on: 20 March 2014, 13:10 »
Im sure you have the same map 3 as me, give it a whirl and it shouldn't feel as aggressive in the lower rpm.
Offline KyleB
« Reply #84 on: 20 March 2014, 17:56 »
Are you recommending 3+1 then Andrew as the optimum map?
Offline virginVWman
« Reply #85 on: 20 March 2014, 19:20 »
240bhp... :shocked:!! That is seriously impressive
Mk VII 3dr GTD in DBP
Fitted DTUK Stage 2 (CRD-T)
Offline Millie_chops
« Reply #86 on: 20 March 2014, 19:32 »
Yip. That's why I'm fairly sure I will be investing in one when I receive my GTD :)
Will run it for a 1000 miles or so first then most likely bite the bullet.
« Reply #87 on: 20 March 2014, 21:01 »
Had to pop to Screwfix to get a mini bit set as those T10 bits are so hard to come by for opening up the DTUK box.
Made the adjustment to 3+1 at Screwfix and drove the 2 miles home. It was wet (for the first time in quite a while) and I don't know whether I was just a bit enthusiastic, but I got my first taste of 3rd gear wheelspin on the move with the DTUK box, with the traction control kicking in very noticeably. I'll see what it is like on a real run tomorrow, whether it needs a bit more control on my part to avoid wheelspin in 3rd. If it does, I will probably switch back to 4+1.
I'll leave mpg out of it because I filled up with Shell (I had a £5 voucher that needed using) - and Esso with 80mL of Millers gives by far my best mpg. Shell without Millers (I added when I got home) gave me 41mpg for my first 15 miles.
So far on 4+1, the car has been transformed with the DTUK box.
Looking at the graphs for map modification settings that Andrew included with the box implies that the 3+1 setting would use less fuel to achieve its output as the signal alteration is noticeably lower than that for 4+1, although there are no implications of the car being wasteful with fuel in terms of soot generation - the cra is doing far less active DPF regenning than it was at stock.
Offline TheCarMadDad
« Reply #88 on: 20 March 2014, 21:31 »
+1
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline ffrank
« Reply #89 on: 21 March 2014, 00:56 »
+1
+2
