Author Topic: mpg issues coolant temperature sensor?  (Read 1850 times)
Offline AD1.8T
« on: 10 November 2013, 17:59 »
Ive had a little search and came across this thread so I dont really need help just opinions.
as of late ive been getting shocking mpg according to the computer I then found the split pcv hose so thought it could of been that but since doing the catch can its dropped even more !
Now my temp gauge does go to 90 and stays there but It takes a good 10 minutes to get to 90 and what seems like forever to drop back to 0 ive been back out to the car 3 hours later and its sitting at 20/30 lol. Im not getting any codes but does it sound like this could be the cause to my mpg issues ?
Offline mcgee9t2
Re: mpg issues coolant temperature sensor?
« Reply #1 on: 10 November 2013, 23:33 »
If stats sticking open I can't see it hitting 90 while your driving. Certainly when it's this type of weather in summer maybe but not winter
Offline Nino
  • Insta - F6UGA
« Reply #2 on: 11 November 2013, 09:35 »
A faulty Temp sensor will cause MPG issues, they are only around £8 fro a replacement, may as well change it, also change the C clip as well cost like an extra 50p.
If that doesn't work Id look on changing the thermostat and for the love of god only use OEM parts.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline WadGTI
  • Golf GTI'er
« Reply #3 on: 11 November 2013, 11:16 »
Sounds like its working correctly to me. If you have found one split hose, there is possibly another your not seeing?
Soapy water spray bottle over the pipes showed me 3 vac leaks i never knew I had.
Offline AD1.8T
« Reply #4 on: 11 November 2013, 15:09 »
All the everything has been changed now mate on crap hose left is the aum charge pipe
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 11 November 2013, 18:14 »
They are two circuit though, it's possible the ECU circuit has gone down but not the cluster circuit. Although it should flag a fault code up...
Offline AD1.8T
« Reply #6 on: 11 November 2013, 19:14 »
Na no fault codes or anything really, just piss poor mpg !
