Author Topic: Changing the glove box and boot light bulbs  (Read 14387 times)
Offline sam67GTD
Re: Changing the glove box and boot light bulbs
« Reply #10 on: 27 November 2013, 16:18 »
Thanks Norbreck21a, you're a gent!  :wink:
I've given up changing these, they will not budge. I can get the boot light (the clear plastic lens) to move back slightly, but I will not pull out. I can't see anyway to remove the glove box light as it's in a nigh impossible location to grip and I've small hands.
I've found this too with the boot light. Managed to get a screwdriver in the slot but moderate pressure wont budge it. Don't want to really force it and be faced with a broken lens cover :cry:
A bit of an update on this. Met up with MkVIIGTD at the weekend and as he has done the mod, he changed my boot light. It's not the Perspex glass that needs to come out (this won't budge), but you need to take out the whole grey plastic surround which you can see around the Perspex cover. You will still need a screwdriver to remove it.
VW Golf R 7.5 | 3 Door | DSG | Lapiz Blue | Black Pretorias | Dynaudio | DCC | Rear Reversing Camera | Black Mirror Caps
Offline Andyduz
« Reply #11 on: 27 November 2013, 19:35 »
Nice one, thanks for the update. Good job I didn't force it. I'll have another go tomorrow, presumably it just pops out and there are no screws holding it in?
Delivered 21st Nov. GTD Pure White, Keyless, Winter Pack, Dynaudio, Tel Prep, High Beam Assist, Climate Screen, Discover Nav, Park Assist, Rearview Camera, Voice Activation
Offline MkVIIGTD
« Reply #12 on: 27 November 2013, 21:54 »
Yup your bang on there,, push screwdriver in around the large grey trim surround and pop it downwards and it should come out with a little gentle talking too lol  :smiley:
Golf MkVII GTD Tornado Red, DSG, Leather, Rear Camera, Keyless
Offline Misterp
« Reply #13 on: 12 December 2013, 20:02 »
So I finally got round to ordering and then trying to fit the boot light - easy job done in seconds. The glove box light not as easy managed to get it out and open
Somewhat confused the bulb that's in there and the LED I purchased two different size and fit bulbs
Can someone advise which bulb I should be purchasing the LED in the pic is a 42mm festoon
Whilst I am here how easy are the static cornering bulbs to change as I have purchased the h7 nightbreaker unlimited.
Thanks in advance.
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Offline monsta
« Reply #14 on: 12 December 2013, 20:29 »
Thanks in advance.
Somewhat strange as I replaced my boot bulb with an LED festoon one today.  You should've have that light holder in there, that is a W5W bulb, you can get these in LED form so not anything to worry about.
Incidentally I'm looking for the housing you have so I can use it for the footwell with a W5W bulb (different coloured).  Can you please let me know the part number that's on the unit?  Would help me in my search without speaking to the dealers :)
Offline Jimble
  • Moderator
« Reply #15 on: 12 December 2013, 22:12 »
Thanks in advance.
The static cornering bulbs are dead easy to change, probably the easiest i've done! Just remove the round cap from the rear of the unit, quarter turn anti clockwise, and lightly push DOWN on the bulb holder and it'll pop out, do the reverse to refit, simples! ;)
Offline Misterp
« Reply #16 on: 12 December 2013, 22:44 »
Thanks in advance.
No holder in the boot. I will get the part number for you tomorrow if i get a chance. However, car going into vw for the suspension issues. As soon as I get a minute I will get the part number.
The w5w bulb do you know where I can get the led equivalent.
Offline Mr Savage
« Reply #17 on: 07 January 2014, 14:00 »
I've done both.
Glovebox
just use your fingers (no tools required) and prise the light out and down out of the aperture. Disconnect the cable (making sure it doesn't disappear back inside). With the light out, use a tiny flat screwdriver and pass it up the gap between the plastic lens and the metal heat shield cage that surrounds it at each of the 4 corners. You will see 4 small notches in each corner of the heat shield, just lever these out very slightly and the heat shield slides off upwards. With the shield off, the bulb then becomes easily accessible.
Boot
From memory, this is even easier as there's no heat shield covering the whole of the back. Just lever the light out of it's housing (there is a small screwdriver cut out at the end you need to remove first).  Once the unit is out and unclipped from the harness, just pop the festoon bulb and and replace with the LED version.
On both just remember that LED's unlike conventional filament bulbs, only work one way round (polarity). So if the light doesn't illuminate at first, just pop the bulb round 180° and try again.
Sorry to bring up an old topic but you make this sound so easy. How the hell do you remove the glovebox light? I can't prise anything as it's all flush and sealed with nothing to prise on?
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
