Author Topic: n249 valve is it worth it?  (Read 2076 times)
Offline tallpaulr
« on: 08 November 2013, 13:15 »
Ive got 1.8t AUM engine with 135k on the clock, will it benefit from fitting one of thwse valve bypasses?
Offline Nino
  • Insta - F6UGA
Re: n249 valve is it worth it?
« Reply #1 on: 08 November 2013, 16:20 »
Bypass the valve totally worth it
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 08 November 2013, 17:00 »
Siome engines don't like it and with throw up the management light. I woudn't bother on a standard car. Too much hassle for very little difference.
Offline tallpaulr
« Reply #3 on: 08 November 2013, 19:32 »
Its got a bit of a flat spot when its pushed would this get rid of it?
Offline Nino
  • Insta - F6UGA
« Reply #4 on: 08 November 2013, 22:09 »
It improves throttle response in my honest opinion
Offline tallpaulr
« Reply #5 on: 10 November 2013, 13:57 »
Heres another question for you all. Ive seen on ebay a n249 bypass valve is it better to use one of these or to bypass it using the method in the thread by BaV using just 3mm pipe?
Offline baxxy
« Reply #6 on: 10 November 2013, 14:50 »
Do the by pass shown in the thread worked a treat for me  :smiley:
Offline tallpaulr
« Reply #7 on: 10 November 2013, 15:01 »
Ive not got an aftermarket dump valve fitted,  would it still work
Offline baxxy
« Reply #8 on: 10 November 2013, 15:24 »
Mine by pass worked fine with the standard DV  :smiley:
Offline Gti_Jamo
« Reply #9 on: 10 November 2013, 15:26 »
If its still a recirculating valve it will work. You don't wanna be dumping to atmosphere on a 1.8t.
